I was thinking the easiest way would be to buy a big old lathe, wouldn't even matter if it had significant wear, and set up the tube in the lathe, and make some kind of a toolpost mounted angle grinder with a buffing wheel on it?
Run on power feed? would this work?
I know more details are needed... the pipe is quite polished already, but needs to become a mirror finish.
there would be hundreds of these tubes to polish.
would the lower Rpm of a vintage lathe be enough?
might work?
might work?
