How to lift a surface plate to stand...without cherry picker or crane etc?
Harbor freight sells them to, I bought one years ago it's been used dozens of times. The table pumps up by foot and it stores easily . I'd invest in one for your lift on the granite. Ok better way for you at two hundred pounds it will slide easy onto the table frame using a piece of carpet turned over with the granite sitting on the backer. Use 2 x 6 lumber from the trailer or truck pull the carpet onto the runners ,,,wood,,, it will slide easy get as close as you can the shorter the span the better. You can use bolts or screws to keep the wood from slipping off the frame or tailgate.
I thought you had something heavy , this is nothing.
Oh no. Not super heavy. I am just leery of dropping things. I've dropped motorcycles out of trucks...I tried moving a rather large 4' wide hearth heater once... dropped that out of the pickup... There are several success stories. But the ones that didn't go well come to mind first. All stuff I did alone of course. lol I did manage to move around a 2700 pound lathe with a speed jack and some sketchy blocking... back before I knew what I had...and I sold it before I knew also! This stone still weighs more than I do and like I said I'm a bit overly cautious anymore. I even wear my jacket every single time I weld. :) The table idea seems cool though with a 20% off coupon cheap.
What ever you do be careful, A hernia or a wracked heart ,or buggered back for a surface table is not a good price to pay, I would seriously consider hiring an engine lift, work safely a serious accident is not what yoou want, some years back I was at the displenishment sale of a pretty skilled toolmaker, who was working alone moving a milling machine, It came over on him & trpped him, Had it not been for a solid steel bench stopping it from mortally wounding him, It would have been unthinkable, He never worked ever again.
I have in the past taken some horrid chances Two hernias later, I wish I had'nt
How about hiring a couple body guards from the local gambling casino to pick it up and place where you want it?
Down here in oilfield country, roughnecks are in abundance. One can handle a 18" x 24" 300 lb surface plate easily.:big grin:
That's what I did for my 18 x 24 pink granite plate. However, I had just recently purchased a 16 x 16 square top small hydraulic lift table on casters that helped the seller get the plate from his shop to my trunk. Two strong friends lifted it from my trunk to the rolling hydraulic stand. I use the rolling stand to move my Starrett vise & 12 inch rotary table on and off of my BP knock off mill and as a rolling tool bench for projects around the large shop. New the lift sells for $400 but I scored a sweet deal on Milwaukee (WI)
Craigslist 20 miles from home for $100.
Paul, my 18x24 two ledge is 4" thick, and also weighs ~200 lbs. My neighbor and I just picked it up off the floor and put it on the stand. It was not a big deal. If you can each lift a 94# sack of cement, you can certainly lift a surface plate together. Just have things laid out so there is nothing to trip over or catch on, just a straight lift, short sideways movement, and set down. No big deal...
The plate isn't super heavy but since I've had issues down south of the waistline in the last year. I do not want to take chances. Kinda why I'm spending time making this easier than normal. I would rather make it super easy on myself than make that happen again. It was so bad the first two weeks when I tried to drive I thought i was going to throw up from the pain. There ya go group TMI :)
