    Dismiss Notice
How to lift a surface plate to stand...without cherry picker or crane etc?
Discussion in 'METROLOGY - MEASURE, SETUP & FIT' started by expressline99, Jun 30, 2017.
  1. expressline99
    expressline99 H-M Supporter - Premium Content H-M Supporter-Premium
    136
    43
    City:
    Reno
    State:
    Nevada
    -Return to Top-
    OK Guys I'm a few days away from being able to mount my surface plate. Figure there isn't any help or another able bodied person around. I don't have a cherry picker or any kind of overhead system. Lucky me I can get it into my van using the forklift at my warehouse. But at home where it's going to live I've got to get it onto the stand I'm building. The stand is going to have a working height of 36" at the top of the plate. I've basically followed "most" of the instruction of the graphic included with the Standridge plate.
    I will be able to get the van within a few feet of where the plate will rest on the stand. The stand is stationary and will be resting on bolts to level it...plus the 3 point mount for the plate at the top. It's 2" square tubing as discussed in the other thread.
    So how do I get it out of the truck and on to the stand alone? I've only got one idea so far and that utilizes a 1/2 ton chain block and tackle I've never used before. But I'd have to build a 4x4 wood rolling frame high enough to use the block. If I had an engine lift it would be a piece of cake. ...and building the rolling frame will be a super pain in the rear. But I will also be able to use it to remove the table from my mill next...and remove the lathe from it's base when I transfer it to the new one.
    The garage is 10' high with a normal 7' garage door. Roof is cut and stack. :) So connecting to those framing members doesn't exactly = safety...likely to come loose and pull the ceiling down with it.
    The only other idea is to make the stand and put the plate on the stand at the warehouse...put the whole thing in my trailer and bring it home... But then I have to get the whole thing out of the trailer. I'm stumped.
    Ideas? Suggestions?
    Paul
  2. mikey
    mikey Active User H-M Supporter-Premium
    2,536
    113
    City:
    Honolulu
    State:
    Hawaii
    -Return to Top-
    Umm, borrow or rent an engine hoist?
    expressline99 and higgite like this.
  3. RandyM
    RandyM United States Global Moderator Staff Member H-M Supporter-Premium
    1,042
    113
    City:
    Stoughton
    State:
    Wisconsin
    -Return to Top-
    What about a couple of rails (any heavy tubing or channel) to a sawhorse, then use some conduit (or round stock) and roll it down the rails to the stand?
    expressline99 and Ulma Doctor like this.
  4. 4gsr
    4gsr Global Moderator Staff Member H-M Supporter-Premium
    2,302
    113
    Victoria, Texas
    City:
    Victoria
    State:
    Texas
    -Return to Top-
    How about hiring a couple body guards from the local gambling casino to pick it up and place where you want it?
    Down here in oilfield country, roughnecks are in abundance. One can handle a 18" x 24" 300 lb surface plate easily.:big grin:
  5. FLguy
    FLguy H-M Supporter - Premium Content H-M Supporter-Premium
    96
    28
    S.W. Florida Ft.Myers
    City:
    Ft.Myers
    State:
    Florida
    -Return to Top-
    When I bought my lathe I had all sorts of ideas on how to get it off the delivery company's truck up few steps into the house and set in place. Not a one was 100% safe so I hired 5 guys; BIG guys, no problems. They were very carefull and had the move complete in about 45 minutes. What ever you do think what could go wrong with that idea before acting on it.
  6. RJSakowski
    RJSakowski H-M Supporter - Premium Content H-M Supporter-Premium
    2,600
    113
    City:
    Barneveld
    State:
    Wisconsin
    -Return to Top-
    Well, the Egyptians were adept at raising massive stone blocks to great heights.
    You didn't say what size or wt. surface plate but a sheet of plywood comes to mind. Cut the plywood larger than the plate but small enough to go through doorways drill some holes for tie ropes to secure the slab. Use 4 x 4's or 6 x 6's stacked to build the height enough to slide the slab from the van to the plywood. secure the slab and remove the 4 x4's, one side at a time until you can lower the plywood to a dolly or cart for rolling to your site. At the site, build the stack up again to the stand height , unsecure the plate and slide it onto the stand.
    Or.... Buy a couple of six packs and go talk with some friends/neighbors (I would still use the plywood. A couple of hand holes would be nice).
  7. tq60
    tq60 United States Active Member Active Member
    224
    43
    City:
    madera
    State:
    California
    -Return to Top-
    Wedge it up...
    When placed in van via fork lift first stack pallets or other materials in first to have it already at correct height or close to it.
    Make a bridge of sorts between there and where it needs to go then slide it across.
    Ww brought home a hf mill drill and slid it out of the van onto a box then with very large screwdrivers we wedged up one side to place a piece of plywood then the other.
    We elevated it well over a foot then slid it onto the bench where it would go...solo but that was in our young and risky days...
    expressline99 likes this.
  8. Ulma Doctor
    Ulma Doctor Infinitely Curious Active Member
    3,004
    113
    Ethereal Plane
    City:
    Tracy
    State:
    California
    -Return to Top-
    rent a hoist and be done with it :)
    kd4gij, core-oil, FLguy and 4 others like this.
  9. higgite
    higgite General Manger - Proofreading Dept. Active Member
    575
    93
    City:
    Houston
    State:
    Texas
    -Return to Top-
    When is the World’s Strongest Man qualifier coming back to Reno? :weight:
    Tom
    4gsr and expressline99 like this.
  10. British Steel
    British Steel United Kingdom Active User Active Member
    465
    83
    City:
    Camberley
    -Return to Top-
    You put it on my back, I'll carry it... ;)
    Dave H. (the other one)
  11. expressline99
    136
    43
    City:
    Reno
    State:
    Nevada
    -Return to Top-
    I wonder why a couple of these ideas seem like the plate goes home with someone else? :) No one has said load it in their car YET. LOL
    Sorry I didn't mentioned it but the plate is 24"x24"x3" it's not super heavy but enough I can't lift it alone. On the stand all four corners will each have a piece of angle iron that sticks up to keep the plate from sliding off and or protecting the corners? But I am wondering if that is even needed with this size of plate. I'll move back over to the support thread for that question. I don't want to weld corners on after placing the stone. Plus I have to paint first.
    So it's wood stacks/rails/ or engine hoist. I would borrow one but I haven't had any mechanic friends for years now. I could probably attract a few people from Sacramento if I bought a bunch of beer and offered food. If they could get here before I drank it all. :D I do have a big bar I built downstairs with some pinball machines.
    Thanks for the ideas folks. I'll have to ponder it out.
    4gsr likes this.
  12. RJSakowski
    2,600
    113
    City:
    Barneveld
    State:
    Wisconsin
    -Return to Top-
    Put the corners on the stand. You don't want that rock walking off over time. Consider bolting at least two on rather than welding. That way you can slide it rather than having to lift it.
    Rex Walters, FLguy and expressline99 like this.
  13. jim18655
    jim18655 United States Active User H-M Supporter-Premium
    344
    63
    City:
    Shickshinny
    State:
    Pennsylvania
    -Return to Top-
    Can you rig a chain fall from the ceiling? I lagged a 2x4 to the bottom of the floor joists and lifted it then slid the stand under and lowered into place. Use 3 joists and I don't think you'll have a problem.
  14. rrjohnso2000
    rrjohnso2000 United States H-M Supporter - Premium Content H-M Supporter-Premium
    80
    28
    City:
    West Lafayette
    State:
    Indiana
    -Return to Top-
    You can sister a 2by to whatever is existing. And support both ends with adjustable basement stantions. Sorry forgot the name. Then go ahead and use that chainfall. Pull and store until next needed
  15. francist
    francist Canada Active User H-M Supporter-Premium
    678
    93
    City:
    Victoria
    State:
    British Columbia
    -Return to Top-
    At 24" square by 3" thick, I make the weight of the plate at less than 200lbs. Hire a 2-man moving crew for half an hour and it would be all done.
    -frank
  16. brino
    brino Active User H-M Supporter-Premium
    2,296
    113
    City:
    Almonte
    State:
    Ontario
    -Return to Top-
    What time should we be there? ;)
    -brino
    mikey, expressline99 and 4gsr like this.
  17. 4gsr
    2,302
    113
    Victoria, Texas
    City:
    Victoria
    State:
    Texas
    -Return to Top-
    My dad built a tool & die cart/lift that I kept from his shop. I put my rock on it, roll it in place, my son and I slid it over onto the surface place stand. we put a couple of slats over the top of the stand to slide the rock over onto the stand. Then pull the slats out. Might see if anyone has one to borrow or rent.
  18. RandyM
    1,042
    113
    City:
    Stoughton
    State:
    Wisconsin
    -Return to Top-
    Here is one of the best tools that I have in my shop. I highly recommend them for every shop. Mine was a Craig's List buy, I use it all the time.
    Lift Table
  19. expressline99
    136
    43
    City:
    Reno
    State:
    Nevada
    -Return to Top-
    Great Idea. I'll bolt two of them on. That way I can still get them painted.
    With the 3 pads on the bottom of the plate I'll have to work around those to keep them from getting pushed off during sliding it on.
    4gsr and brino like this.
  20. expressline99
    136
    43
    City:
    Reno
    State:
    Nevada
    -Return to Top-
    I would love to have one of those!
  21. expressline99
    136
    43
    City:
    Reno
    State:
    Nevada
    -Return to Top-
    Now would work. It's 94 outside I think I'm going to go have a cold one or two...and keep working on that stand.
  22. expressline99
    136
    43
    City:
    Reno
    State:
    Nevada
    -Return to Top-
    Based on what I've seen in the attic I don't think it would support it. But it might. I've been up there and haven't fallen through yet. I could get some 12' 2x6's and put those on each side of where I'm lifting to give it more support. That's a possibility.
    4gsr likes this.
  23. expressline99
    136
    43
    City:
    Reno
    State:
    Nevada
    -Return to Top-
    Yeah it's not horribly heavy. But alone a little too much. I'm not a very big guy. But Ken's got guys working around him that can lift 300 pounds. I think if I tried just dead lifting it I might have some internal part breakage! :)
    Ulma Doctor and 4gsr like this.
  24. expressline99
    136
    43
    City:
    Reno
    State:
    Nevada
    -Return to Top-
    That might be the way to go. The hard part is connecting those to the 10' ceiling. Really some of those spinning adjustable stanchions would be the way to go. Like those used to support floors while replacing load bearing walls. I think that's what you mean?
    Ulma Doctor likes this.
  25. expressline99
    136
    43
    City:
    Reno
    State:
    Nevada
    -Return to Top-
    I love watching that. Did they have it here and I didn't realize it??
  26. higgite
    575
    93
    City:
    Houston
    State:
    Texas
    -Return to Top-
    I only watched a few episodes awhile back. I’m pretty sure one was in Reno, biggest little city and all that, but I’ve slept since then. ;)
    Tom
  27. NCjeeper
    NCjeeper United States H-M Supporter - Premium Content H-M Supporter-Premium
    551
    93
    City:
    Charlotte
    State:
    North Carolina
    -Return to Top-
    If you were closer I could help you out and pick it up.
    Ulma Doctor and expressline99 like this.
  28. FLguy
    96
    28
    City:
    Ft.Myers
    State:
    Florida
    -Return to Top-
    I have a 2 ton table lift I bought from a Industrial Liquidatetor for $220.00 new, in the crate. I use it as an additional work surface; help moving friends;getting heavy things from the freight delivery tucks into the shop which is deep inside my home. Wish I had bought it LONG time ago.
    Ulma Doctor and RandyM like this.
  29. wawoodman
    wawoodman himself, himself H-M Supporter-Premium
    645
    113
    Seattle, WA
    City:
    Seattle
    State:
    Washington
    -Return to Top-
    Ulma Doctor, expressline99 and FLguy like this.
  30. Silverbullet
    Silverbullet Active Member Active Member
    864
    113
    City:
    Marlton
    State:
    New Jersey
    -Return to Top-
    Harbor freight sells them to, I bought one years ago it's been used dozens of times. The table pumps up by foot and it stores easily . I'd invest in one for your lift on the granite. Ok better way for you at two hundred pounds it will slide easy onto the table frame using a piece of carpet turned over with the granite sitting on the backer. Use 2 x 6 lumber from the trailer or truck pull the carpet onto the runners ,,,wood,,, it will slide easy get as close as you can the shorter the span the better. You can use bolts or screws to keep the wood from slipping off the frame or tailgate.
    I thought you had something heavy , this is nothing.
Share This Page
