4
How to hold a tap in the tailstock?
3
Like what you see?
10
BGHansen
H-M Supporter - Premium Member
H-M Supporter-Premium Member
Nov 23, 2014
726
Likes
1,616
#31
I use a spring loaded center (shop made) also. I've been using a piloted tap wrench lately (picture below). Bought a pair that goes from 1/16" - 1/2" off eBay from a seller in GA for about $40 delivered. I use the piloted tap wrenches in the drill press and vise also.
Bruce
Bob La Londe
Active Member
Active Member
Apr 19, 2014
237
Likes
127
#32
I just use a standard drill chuck -- just for the reason you pointed out, the the tap will slip when it meets the bottom of the hole, or when the resistance gets to much (taps are hard and wont mar like a drill bit). I do have variable speed and this is done very slow. At the first slip, I reverse and will usually try again and get a thread or two more, if needed then I finish the threads with conventional means by hand. (use lots of thread cutting oil!)
I have to admit I power tap on the lathe sometimes. Just did 4 x M10-1.5 pieces in 6061 over the weekend... with a hand tap. Usually I use machine taps, but I didn't have any that size. Made me cringe, at first, but I did like you except when I reverse it out I add a drop or two of TapMagic and it usually finishes the hole. The stuff really is amazing. I use the all metals formula. Never have tried the one that's "formulated for aluminum."
I have been thinking about getting another Jacobs/MT taper for the tailstock on my big lathe and mounting a tapping head. Then I can count on the clutch in the tapping head to stop me from breaking taps. I usually tap at about 70 RPM (the slowest gear speed on the 1440). I don't power tap on the baby 7x10/16 as it has nearly no torque at low speed. Even in low gear. The 8.5 x 18 is belt drive so I guess I could reverse the pulleys and get good torque at low speed, but its a dedicated collet machine for small round stock now. I do tap some teflon parts I make on it, but teflon takes nearly no force, and its self lubricating.
Bob Korves
Jul 2, 2014
4,032
Likes
4,179
#33
I only run small tap drivers, like this one, MT6. Does anyone have an adapter so I can drive the pictured tap?: :eek 2:
(conversation piece and paperweight) Anybody have a real use for it?
Bob La Londe
Active Member
Active Member
Apr 19, 2014
237
Likes
127
#34
Dang. I'd love to, but the spindle bore on my biggest machine is MT5-1/2 and the tails tock is MT4.
Wreck™Wreck
Sep 29, 2014
1,918
Likes
1,462
#35
Have never had a problem holding a tap in a MT tap holder in a turret, holding the part in a 3 jaw chuck is more difficult.
4gsr
HM Chief Foreman
Staff member
Aug 8, 2011
4,404
Likes
2,665
#36
I've never had a problem power tapping in the lathe using a drill chuck. Tighten the tap a little tighter that normal for a drill of the same size. No cheater pipe used. Use a good cutting oil like Mobilmet 766 and get after it. If the tap starts to spin, I stop, back the tap out, clean chips out, go back using a tap wrench to finish up the job.
Franko
Feb 24, 2015
1,286
Likes
1,056
#37
I have one of these. It works great. It also has a gizmo to hold dies. The holder slides on a rod so you can feed it forward. If it gets stuck, it just spins in your grip. I don't know that I've ever had to use the bar that goes in the hole. The knurled barrel provides lots of grip. Mine just chucks in the drill chuck.
brino
Jan 2, 2014
2,843
Likes
2,618
#38
Franko, is that shop made? I really like to see the die holder too. (or a pointer to the vendor)
Thanks, -brino
Franko
Feb 24, 2015
1,286
Likes
1,056
#39
Brino, they are not shop made. I purchased them. They shouldn't be that hard to make. The hard part would be attaching the tap chuck to the outside tube.
My tap holder fits in a drill chuck. It is limited to 1/4" and smaller taps.
I couldn't find it online and don't remember where I got it.
(Memory is the second thing to go. I don't remember what the first thing was.)
The Die holder uses a M2 taper. I got this at Little Machine Shop.
These are pretty useful and available at many sites. Large and small holders with a square hole for socket wrenches.
You can also stick a hex socket adapter in them and chuck them in a cordless drill with a hex to square socket adapter.
My most used method of tapping is by chucking a tap in my cordless drill and setting the clutch low. I've never broken a tap with that method. It is good for quickly backing the tap out to clear it. I never had much problem starting them crooked. I'm pretty good at holding a drill at 90º. Some people aren't so that might not be recommended for them.
Bamban
Jul 13, 2014
603
Likes
426
#40
I power tap using ER32 collet chuck with MT3 shank. Just like how Ken does, I don't gorilla tighten the nut. If and when tap slips, I hand finish the work, have not broken a tap.
6
5 7
