Hi Charlie
My lathe is a 14/20 and I use CXA. The wide part of the dovetail is approx 2 3/16" and the narrow is 1 11/16". If you check your boring bar dove tail that should tell you. Just thought I'd mention that all CXA's will fit , no need to by Aloris unless you want to. Good luck
dickr
ps If you have a catalog, Travers or MSC supply I believe they have the measurements in them. They'll also send a catalog if you barely ask. Ask for the machine catalog not the whole thing it ways a ton coarse bein a young fella you probably wouldn't even notice.
