How to cut narrow angles (chamfers) on minlathe?
matthew-s
Jan 15, 2015
34
Hello all:
I have a Micromark 7x16. There have been a few times where I've needed to cut a very shallow angle (say 15* or less - such as the chamfer on a bolt head)
I overcame one issue - the fact that the protractor is only graduated to 45*, by using a separate adjustable protractor.
The second issue is that at these angles the cross slide and compound dials crash into each other - you cannot feed the compound direction w/o hitting the cross slide dial.
Is there anyway to overcome this? Am I missing a simple solution? One way I suppose it so grind a tool bit to this angle, but I've found pretty quickly the lathe runs out of rigidity and you get a lot of chatter.
Thanks,
Matt.
Are you able to swing the compound around so the dial/handle is at the rear?
-Mark
-Mark
Only if I remove the chip guard! Not at all difficult (I need to get behind the machine and unscrew it all), but geez, sure seems like it should not be necessary!?
I normally use a file, or just bring the edge of the tool bit in and touch the edge, then maybe finish with a file. Safety note: Make sure you use a file handle and keep clothing and body parts away from the spinning things when using a file. :eek:
Darn chip guards. Not that I'm against safefy, but they sure get in the way sometimes. I think the majority learn to work safely without them
-Mark
-Mark
Sometimes! Although in this case it keeps me from growing a swarf pile behind the machine, so I sort of like this one!
I'm with Jim. Most of the time I just rotate the tool and use the edge of the tool I'm using to turn the work piece and put a quick chamfer on the end. Takes a few seconds.
I have a dedicated chamfer tool. It looks sort of like a threading tool except with a 90* included angle. Makes a 45* chamfer. With a QCTP, it’s quicker to change tools than mess with adjusting the angle of the tool post or compound. But, that’s a 45* chamfer. For your 15* chamfer, you could use a similar tool with a 15* face or a tool with whatever angle and turn the tool post as Mikey suggested. Lots of options.
To just knock an edge off, I use a file like Jim suggested.
Tom
On my 9x20 I extended the rear of the splash guard by around 12" to get more clearance for what I didnt know at the time but since it has been a "temper" saver.
Might be worth a look to see if its a viable option for you.
Mines at post 14
