- May 4, 2015
- 3,583
You can still grind it while in the lathe with a good indicating job. The gear will be flat and squared to the bore. With a dremel strapped to your tool post you can grind and polish the faces and then your bore if needed. You can even do the key way by turning the lathe handle moving the compound in and out with the head locked in back gear and motor off. Keep old towels dampened with light oil the sparks and metal will stick and not get in the lathe. It will take time to set up face and bore to grind but it can be done.
