    Dismiss Notice
How Reliable Are Variable Speed Controls
Discussion in 'MINI-LATHE & MINI-MILL INFORMATION' started by herrwood, Aug 24, 2016.
  1. herrwood
    herrwood United States H-M Supporter - Premium Content H-M Supporter-Premium
    2
    3
    City:
    perrineville
    State:
    New Jersey
    -Return to Top-
    Looking to get a mini lathe to play with , was looking at a few of the smaller grizzles the 7x14 would most likely satisfy my needs but not a real fan of electronic things that usually break and i can't fix. So I see the 9 x 19 they have is a manual setup (saw the 10 but that won't work for the space I have).
    So the question is how reliable are the electronics and these smaller lathes, I do realize a little more set up time as i have a belt driven wood lathe.
  2. mksj
    mksj Active User H-M Supporter-Premium
    1,310
    113
    City:
    Tucson
    State:
    Arizona
    -Return to Top-
    Often with electronics they will fail either early on because of a bad component or last for a long time and then fail. Some components have a finite lifespan, like electrolytic capacitors. On these type of machines there is usually a single control board that is easily replaced and would be covered by the warranty if early on. I do not see this as a limiting factor.
  3. herrwood
    2
    3
    City:
    perrineville
    State:
    New Jersey
    -Return to Top-
    That does make sense , I do realize the electronics make operation easier then making belt changes.
Share This Page
