You might look at putting a temporary sub frame/loading dock over the steps that would allow you to lift tools with tractor and set them on. Then you can push/pull/drag them into shop.
Might be awhile before I get out your way, considering I am on the other side of the world from you. I am about 4 hours North of Spokane, Washington in Nelson, BC, Canada. Some say it is the Northern state located between Washington and Alaska.
I used a jib pole on my tractor frontend loader to set mine thru the door and onto the stand. It all fit with about a couple inches to spare and we rolled it to it's final spot.
Bobby
