Mine looks almost identical to shadow's but it is 3" diameter, used 3/8" set screws and has a No 4 Morse taper drive end.... I use it with a 3/4" square HSS tool.
DaveH, I really like that. I have a R8 blank that needs a purpose, and I also have a bunch of carbide bits with no toolholder.
What I need is a large swing flycutter for surface finish . Something like 4" diameter.
I may have to play with that a bit. Thanks for the inspiration
I built a fly cutter and brazed on an old carbide insert to make a fly-cutter in shop class but I "REALLY" like the removable inserts I see here !! Now I know another use for all my extra inserts.
