    Dismiss Notice
How do you replace the bearings in a motor?
Discussion in 'ELECTRICAL ISSUES - POWER YOUR MACHINES & SHOP' started by Nels, Apr 10, 2011.
  1. Nels
    Nels United States Founder Staff Member H-M Supporter-Premium
    764
    113
    Eastern Queens, NY
    City:
    Eastern Queens
    State:
    New York
    -Return to Top-
  2. wawoodman
    wawoodman himself, himself H-M Supporter-Premium
    486
    83
    Seattle, WA
    City:
    Seattle
    State:
    Washington
    -Return to Top-
    Nelson,
    I just googled "bearing shop queens NY" and got 3 hits. Once you get the old bearings out, just take them to the nearest shop. Generally, bearings are pretty reasonable.
    A puller and a press will be your friends.
    brino likes this.
  3. Starlight Tools
    Starlight Tools Active User Active Member
    16
    38
    City:
    Nelson
    State:
    British Columbia
    -Return to Top-
    Nelson
    Bearings are relatively easy to get ahold of. I keep dozens in staock and so would any small motor or other repair shop. Also there are industrial bearing houses and many car type parts stores.
    Bearing removal, I have dozens of different bearing pullers and press fixtures just to facilite that. My Arbour press is what I will use most of the time. Supported by bearing knives like shown in the front page of that youtube video. If the rotor is too large in diameter to fit the arbour press, then it is either the big H-Frame Hydraulic press or a two or three arm puller, or a strong back puller like shown on the youtube picture. Bench grinders can be a bit tricky in that the shaft is really long for bearing pullers.
    Walter
  4. Starlight Tools
    16
    38
    City:
    Nelson
    State:
    British Columbia
    -Return to Top-
    Also
    Bearing heaters are pretty rare beasts, very few home shops will have them.
    When ever possible, and unless you have grease fittings on the motor, err for 2RS bearings with the two rubber seals. Open and shielded bearings let too much crap into the bearing in typical applications
    Walter
  5. Nels
    764
    113
    Eastern Queens, NY
    City:
    Eastern Queens
    State:
    New York
    -Return to Top-
    Walter,
    I understand how a puller like the 2-jaw puller in the video is used, but I'm lost on how the arbour press works to separate the bearing and properly replace the new one. Perhaps a photo?
    Thanks,
    Nelson
  6. Nels
    764
    113
    Eastern Queens, NY
    City:
    Eastern Queens
    State:
    New York
    -Return to Top-
    Can someone identify these pullers?
    So many pullers needed to do bearings. Can someone identify the ones in these photos please? ::headscratch::
    Thanks!!
    Nelson
    markba633csi likes this.
  7. Fishchips
    Fishchips Active User Active Member
    0
    16
    City:
    Amarillo
    State:
    Texas
    -Return to Top-
    The first pic pullers are for bearings close to the end of the shaft, the other for a bearing deep on a crankshaft ie air compressor crank. I use a coiled single element hotplate for installing bearings.
  8. StonewellMark
    StonewellMark United States Active User Active Member
    0
    16
    City:
    Gardiner
    State:
    New York
    -Return to Top-
    I just re-wired (some dumbass previous owner cut the wires just outside the motor housing), and replace the bearings in my rockwell tool grinder. The bearings are easy to come by, just get the part number off the old ones, find a set of Timkens. What a pain to re-assemble, I kept deforming the starter spring "plate" and the grinder wouldn't start, just hum. Then I got "smart" and used an ohm meter during re-assembly walla a working motor. As far as pullers I just used a cheapo 2 jaw puller. Best of luck.
    Mark
  9. Terry Lingle
    Terry Lingle Canada Swarf Registered Member
    1
    3
    City:
    Birch Island
    State:
    British Columbia
    -Return to Top-
    a bearing heater is as simple as a 60 or 100 watt light bulb in a stable socket just balance the bearing on the bulb and flip the switch after 5 min or so flip it over ( the actual time is bearing and bulb dependent) but the objective is even heat on the inner race. I try for about 220 Deg F or spit sizzles temperatures .
    A clean journal and a light wipe with never seize. with a little practice the bearing should slide into place with firm hand pressure ( wear gloves )
    Tozguy likes this.
  10. gonzo
    gonzo United States Active Member Active Member
    60
    18
    City:
    farmville
    State:
    Virginia
    -Return to Top-
    On some of the larger motors the end bells have to go back on the end they came off of and the orientation kept the same as before. The best way is to punch a set of dots on adjacent surfaces before disassembly.
    Sometimes when this is not done the shaft will lock up upon reassembly.
    This is mostly a problem on larger motors with cast iron bells. However it's good not to take a chance.
    Tozguy likes this.
  11. Silverbullet
    Silverbullet Active Member Active Member
    554
    113
    City:
    Marlton
    State:
    New Jersey
    -Return to Top-
    The puller set up in the second picture will do what you need , use the smallest separator then bolts to your puller. It won't hurt to use a bit of kroil on the shaft as you pull it. Bearings can bought lots of places Grainger , McMaster Carr , eBay . They are usually sealed bearings so most any of the shielded type in your size will work. Heating bearing may not be necessary , many times I find it easier to freeze the shaft overnight in a freezer . Usually the bearings drop on with light pressure. Then it's just putting it back together. Try not to rub any of the finish off the wound wires. Any dirt use a soft brush lightly clean what you can. If you have a brush run motor take care getting those in.
  12. firestopper
    firestopper H-M Supporter - Premium Content H-M Supporter-Premium
    1,296
    93
    City:
    Tucson
    State:
    Arizona
    -Return to Top-
    When it comes to pulling bearings, one single tool will not work every time. The good news, many folks who have a decently equipped shop can modify generic pullers to get the job done correctly. The ability to machine and weld will save you time and money. Using tricks such as freezing and heating also go a long way. Pressing in new bearings is IMO far easier than pulling old ones. That said, I have found using a die grinder equipped with a thin cutoff wheel to score an old bearing race (on the shaft) in two or three places followed by a few light strike will result in success in removing. Obvious precautions taken to protect unwanted contamination while grinding. Over time this has become a less frequent operation as the collection of home made tool, shims etc are kept for the next bearing job that might come up, but always an option.
    As far as procedures on electric motors, I have only done a few Makita 4" grinders and smaller 2 hp or less sealed motors. On motors that I can't find information on, I start of by marking both ends with an indexing line for later reassembly. Remove the long screws and tap the shaft end cap with a small brass or soft hammer.Once it begins to move, Its pulled evenly off. Then the rotor assembly is pulled straight out slowly keeping track of any shims, spring washers etc. The inside of the motor can be cleaned out using low pressure air and electronic spray cleaner (air usually works well enough). Depending on bearing set back a pulley puller could do the job, but always soak the shaft with penetrating oil.
    I recently replaced the bearings on a Rockwell/Delta finishing machine. This is how I proceeded.
    I had room to use a generic pulley puller for both bearings. This type of puller will damage the bearing being pulled out but who cares, they're already shot.
    Here you can see the indexing mark I mentioned on the rear end cap and housing as well as the shims and spring washers in the lower right. I should have mentioned the fan on the rear was removed prior to disassembly (snap ring).
    The rotor assembly shown was in great shape for a 34 year old motor. The right end of the rotor is the rear and shows the centrifugal switch and was also inspected prior to installation of new bearings.
    The pressing operation went smooth and an old sleeve was used for this. The custom sleeve was turned long ago for a different job and lives in a bucket along with other pieces next to the press. The sleeve should slide freely on the shaft (OD) and contact the inner race of the new bearing only. I froze the bearing in a Zip-loc bag for 40-60 minutes prior to pressing. The bearings also had a small shim for them to seat agents once pressed (most of them will) but make sure they do prior to pulling old bearings. If no shoulder is found, then careful measurements should be taken to ensure proper depth of new bearings.
    Nothing fancy about the HF 20T press. Its the correct tooling that makes it work.
    These quality bearings found on the shelf at a local bearing house. All the bearings on the machine where a shielded type except one. I replaced them all with Koyo sealed bearings to keep the grit out. These new motor bearings ran under $5 each so check your local sources. On the upper left, you can see the sleeve that was used to press the new bearings in.
    The inside of the motor after using low pressure air (40 psi) to clean out. Looks amazing considering its age.
    Reassembly of the rotor;
    You must be carful not to contact the rotor to the stator and line up the bearings to the end caps with all the correct shims in place. I was lucky to have an extra set of hands for this. The end caps have bearing bosses that retain said shims. A light coat of dielectric grease helps keep them in place during assembly. Once you verified everything is lined up properly you can begin to tighten the long screws evenly in a criss-cross pattern pausing to gently tap around the end cap using a mallet or small dead blow until fully seated and spinning the shaft by hand (during the process) to ensure all is well. Reinstall rear fan and vented cover and bench test if you feel the need. We installed the motor and then tested. It runs like a new motor without the grumbling it once had. I also replaced the start capacitor for good measure.
    I hope this answers some questions and can be of help.
    Turn and burn,
    Paco
    MrDan, cmantunes, Fitter Bill and 2 others like this.
  13. markba633csi
    markba633csi United States Active Member Active Member
    237
    43
    City:
    Mountain View
    State:
    California
    -Return to Top-
    Looking at all those pullers reminds me of all the tools I still don't have :D
    Mark S.
    Ken from ontario and 4gsr like this.
  14. talvare
    talvare United States Ted A H-M Supporter-Premium
    302
    63
    City:
    Sacramento
    State:
    California
    -Return to Top-
    Nels,
    There's a lot of good information given here for you. One thing I didn't see mentioned is the importance of how the new bearings are driven or pressed into place. If the new bearing is being pressed or driven onto a shaft, drive ONLY on the inner bearing race. If a new bearing is being installed into the end bell (usually not the case) or a bearing housing, drive ONLY on the outer bearing race. For removal of the old bearings it doesn't make any difference as they are being disposed of.
    Ted
    Rustrp and brino like this.
  15. firestopper
    1,296
    93
    City:
    Tucson
    State:
    Arizona
    -Return to Top-
    Mentioned in post. This is very important!
  16. machPete99
    machPete99 United States Iron Registered Member
    6
    3
    City:
    Kingston
    State:
    New Hampshire
    -Return to Top-
    You can probably use a piece of pipe to tap the new bearings in. Just make sure that it only hits on the inner race, as others have noted.
    4gsr likes this.
  17. markba633csi
    237
    43
    City:
    Mountain View
    State:
    California
    -Return to Top-
    I've found that many standard pipe sizes make nearly perfect tooling for pressing metric size bearings like 6200 series for example.
    A 1.25" piece fits the outer race perfectly without hitting the shield. Half inch piece for the inner race.
    MS
  18. tertiaryjim
    tertiaryjim Active User H-M Supporter-Premium
    170
    43
    City:
    Naturita
    State:
    Colorado
    -Return to Top-
    When using a puller, put a protective cap over the end of the shaft so the center isn't damaged.
    If the shaft has to be set up in the lathe, a bad center hole will make you crazy.
    4gsr likes this.
  19. 4gsr
    4gsr Global Moderator Staff Member H-M Supporter-Premium
    1,736
    113
    Victoria, Texas
    City:
    Victoria
    State:
    Texas
    -Return to Top-
    Sometimes I'll take a hex nut like a 3/8 or 1/2 and put it between the center point of the puller and the end of the motor shaft to protect center in the end of the shaft.
    I remember having to fix a center in the end of a motor shaft from a 75 HP DC motor before I could recut the commutator. The lathe I was on did not have a way to install a drill chuck in the tail stock or anyway to hold a drill chuck in the tool post. Had to grind a tool to go in and touch up and remove the dings at the front of the center. I was doing this on a 36" Monarch lathe with a make shift adapted steady rest!
    blackelim likes this.
  20. tertiaryjim
    170
    43
    City:
    Naturita
    State:
    Colorado
    -Return to Top-
    4gsr
    A messed up shaft center was one of my pet peeves. Had to deal with a number of them.
    Terry Lingle already mentioned using a little never seize when installing bearings but I would like to add to that.
    Too much never seize takes up space and can change the clearance of the bearing. It can also make a race seize to the shaft slightly crooked.
    Small effects but they can cause problems or reduce bearing life.
    Never seize applied too thick can also cause a bearing to score or gaule to the shaft on removal. Seen it!
    I will put it only on the fit if the bearing is being heat shrunk. Most small bearings have only two tenths interference.
    If pressing the bearing on I will put it on the shaft and race but in all cases its spread so "thin" you can hardly tell there's anything there.
    4gsr likes this.
Share This Page
