- Mar 30, 2014
- 115
Pretty simple. How in the world can I hold a axle shaft in my lathe? Its a outer axle shaft from a 4wd front axle. One end has splines, the other has a u-joint yoke. Here's the problem, I need to hold it on the u-joint yoke end, because I need to machine the end with the splines. They have center drilled spots on both ends, from when they were made. If I take my chuck completely off my machine, I can put it between the centers, but naturally, with no chuck or plate on it, there is no way to turn the shaft. I do not have a face plate or lathe dog, but even if I did, the center on the spindle would be too short. to reach past the ears to the center divot.
I need to cut another snap ring groove. These shafts were originally for drive flanges, so they don't have the snap ring groove in the right spot for lockout hubs. Now production shafts have both snap ring grooves, but I do not want to spend $85 each for new ones, when these are perfectly fine, they just need another groove.
Looking for any suggestions.
Here are a couple pictures. First you can see the center divots, next is showing the splines and I have roughly marked with a sharpie where I need to cut another snap ring groove. Last is a link to ebay showing a new shaft and it shows more clearly the groove I need to cut.
Here is the ebay link:
http://www.ebay.com/itm/FORD-F150-1...-79-/370890625381?hash=item565acdd165&vxp=mtr
