- Jun 12, 2014
- 4,806
Made a video of my PM1340GT lathe vibration stability vs. speed. I think mass loading the bases and some bracing may go a long ways to enhance stability, I have about 200Lbs on shelving between the lathe cabinets. You could do a larger steel perimeter base frame with rectangular steel (2x6 or something like that) and weld some studs or threaded inserts for mounting the cabinets to. I would then pour cement into the rectangular steel tube or you could make a bottom plate and pour cement into the center of that.
Probably a matter of fine tuning of the feet, but no machine in this weight class is going to be rock solid. Bolting to the foundation should make a significant improvement, but that is not always an option.
