- Feb 17, 2017
- 30
I started a thread about a new lathe I've purchased. It hasn't arrived yet. (Grizzly G0740 Heavy Duty 3-phase 14 x 40). My dilemma is whether to buy/build a RPC or simply change the 3-phase motor(s) with new single-phase.
The lathe comes with a very-wide speed range of 50 to 2,500 RPM. I can't imagine ever needing 2,500 RPM. So maybe a 1,750 RPM single-phase 5-HP motor would provide all the power and speed that I'd ever need. The 2-speed switch would then not be needed, but could stay in one position. The wire size within the lathe should suffice. I'd need to rewire the motor circuit, but that should be simple . . . even including rotation reversal via the apron control. The lathe would be changeable back to 3-phase, should a future buyer desire 3 instead of single phase power input. Reversible 5HP motors appear to be common and fairly inexpensive. A drive pulley change would probably be in order.
Any comments or ideas? Lathe is coming in less than 10 days.
