- Aug 28, 2014
- 315
Every now and than in a thread it shows up: warnings that you cannot run a screwed on chuck backwards while threading, because it will unscrew and reek havoc.
Now, who has actually SEEN this happen.
I mean SEEN, not heard about it.
And SEEN not on a monster lathe taking .050 passes on a giant thread, but on a normal lathe taking 0.005 passes on a normal thread.
I will tell you that, other than the fool who put the chuck on just before threading and did not tighten it,
NOBODY will have seen it happen.
Next time you are threading switch off the engine and turn the chuck by hand using a spanner on a jaw.
Now after the threading is done ,block the backgear and try to unscrew the chuck using the same force on the same spanner......
