    Dismiss Notice
Homemade Edm To Remove Broken Taps
Discussion in 'PROJECT PLANS & DRAWINGS' started by Billh50, Nov 22, 2015.
  1. Billh50
    Billh50 Active User H-M Supporter-Premium
    890
    113
    City:
    New Britain
    State:
    Connecticut
    -Return to Top-
    I found a page with some basic plans for an EDM to remove taps. And since we all break taps now and then, I thought I would post a link.
    http://pico-systems.com/edm.html
    BRIAN, brino, royesses and 6 others like this.
  2. kvt
    kvt Active User Active Member
    471
    83
    City:
    San Antonio
    State:
    Texas
    -Return to Top-
    Thanks for the link
  3. Morgan RedHawk
    Morgan RedHawk Active User H-M Supporter-Premium
    32
    28
    City:
    Columbia
    State:
    South Carolina
    -Return to Top-
    I have been thinking of building and EDM, too. This guy has books and PCBs for 2 types. I am thinking about ordering the book for the pulsed version.
    http://www.homebuiltedmmachines.com/
    I am wondering, how do you shape the electrodes for custom shapes?
    Any input from anyone that has built or used an EDM would be appreciated.
  4. Billh50
    890
    113
    City:
    New Britain
    State:
    Connecticut
    -Return to Top-
    The shaped electrodes are usually made from a carbon rod. They are machined for the shape needed.
    uncle harry, kd4gij and Ulma Doctor like this.
  5. uncle harry
    uncle harry United States Active User Active Member
    266
    63
    City:
    Big Bend
    State:
    Wisconsin
    -Return to Top-
    Copper has also been an electrode material. I've had hardened S7 alloy edm shaped to de-gate dozens of very small plastic parts for pick and place decades ago. Since graphite is the electrode of choice some shops have specifically isolated rooms with lathes, mills and other tooling to isolate the mess from other areas.
  6. Billh50
    890
    113
    City:
    New Britain
    State:
    Connecticut
    -Return to Top-
    Well every place I have worked that had an EDM used the graphite or carbon rods for shapes. They also used the copper for burning thru taps and broken dowel pins.
  7. Smithdoor
    Smithdoor United States Active User Active Member
    66
    28
    City:
    Clovis
    State:
    California
    -Return to Top-
    looks great
    Thank you
    Dave
  8. ch2co
    ch2co United States Grumpy Old Man H-M Supporter-Premium
    308
    63
    Mile High Colorado
    City:
    Center of Colorado 5362ft
    State:
    Colorado
    -Return to Top-
    Add anther small project to my to do list. Looks like fun to try out. I've seen commercial EDM's working, but never thought that
    it would be so simple for a hobby shop. Thanks!
    CHuck the grumpy old guy
  9. bpratl
    bpratl United States Active User H-M Supporter-Premium
    53
    48
    City:
    Gloucester
    State:
    Massachusetts
    -Return to Top-
    Just added this project to my very long DIY list. There has been many a time that I could have put this to use.
    Thanks again for sharing. Bob
  10. Billh50
    890
    113
    City:
    New Britain
    State:
    Connecticut
    -Return to Top-
    I was thinking about the one I posted. If some electrode holders were made to take different diameter copper tubing. Then a holder for them to be mounted into with a fitting and hole to allow fluid to flow thru tube. That would keep the grit out of the hole that is being burnt. This would work just like conventional machines.
  11. RJSakowski
    RJSakowski H-M Supporter - Premium Content H-M Supporter-Premium
    1,956
    113
    City:
    Barneveld
    State:
    Wisconsin
    -Return to Top-
    How about using hypodermic tubing for the electrode? 18 ga. (.050) tubing has a resistance of less than 1 ohm/ft. McMaster Carr sells it as precision miniature stainless steel tubing from .008" to .253" O.D.
    Bob
  12. John Hasler
    John Hasler United States Active User H-M Supporter-Premium
    758
    113
    City:
    Elmwood
    State:
    Wisconsin
    -Return to Top-
    It isn't just about the resistance. The electrochemistry matters as does thermal conductivity.
  13. 4gsr
    4gsr Global Moderator Staff Member H-M Supporter-Premium
    1,396
    113
    Victoria, Texas
    City:
    Victoria
    State:
    Texas
    -Return to Top-
    The old tap burner dad and I used to, toohave, an old Elox brand, we used plain water for the coolant and wen to the local hobby shop and bought brass tubes from 1/16" all the way up to 5/8" in size. We had all sorts of fittings for adapting the tubes to, an some of them we soldered them to the fitting. We redesigned the tap burner a little from original, replaced the collet system they had to a 3/8" NPT thread to simply things.
    With the welders of today available to us, I would not hesitate taking one with spark gap control and adapting it to a tap burner. The vibrating head used on one can easily be made from a solenoid used to open a valve stem. just put a limit switch on the end to break the circuit momentary, letting the solenoid go back up, hitting the limit switch again. There are other ways of creating the "vibrating" thing needed to control contact of the electrode with the work.
    Ken
  14. Billh50
    890
    113
    City:
    New Britain
    State:
    Connecticut
    -Return to Top-
    I do remember buying small copper tubing from hobby shops years ago. We would cut and solder the tubing to make a chassis for slot cars. They had several small sizes.
  15. mark_f
    mark_f Global Moderator Staff Member H-M Supporter-Premium
    1,680
    113
    City:
    Mercer
    State:
    Pennsylvania
    -Return to Top-
    Some of you may have seen it , but I am building Ben Fleming's Pulse EDM machine on here now. It is not a cheap thing to get into, but can be very useful. You can build a simple tap burner very cheaply, but as many of you know ( when I build things), I got carried away and am building a much more versatile machine to do a lot more than tap burning. I used EDM in the machine shop many years ago ( when vacuum tubes were the rage) and they can do a lot of machining operations you cannot do on the mill or lathe. If interested, check it out in Members Projects.
    JohnnyTK likes this.
  16. whitmore
    whitmore United States Iron Registered Member
    6
    3
    City:
    Shoreline
    State:
    Washington
    -Return to Top-
    I've used tungsten rod, for EDM'ing narrow holes (0.040"), in boron carbide. By tungsten,
    I mean the soft tungsten metal, available as wire, not tungsten carbide. Kerosene bath
    with a pump to flush the cut (Shell Diala AX specifically, but it sure looked like kerosene).
    We used an aircraft 28V oil pump, but I see lots of 12v diesel/fuel pumps for automotive
    use that would probably circulate fluid just fine.
    I recall some cuts worked best with the wire probing UP into the work.
    What I do NOT recall, is if the whole apparatus cranked up from the coolant tank, or whether
    the tank dropped down to set up the tooling and workpiece.
Share This Page
