- Sep 13, 2011
- 271
I came here because of some information on a home made taper attachment for a lathe. I found a lot of good info, and together with what I have pictured in my mind I believe that I can make a simple but strong and easy to use unit.
However (you knew there was a catch) I have a question.
During the use of the taper attachment there is a force upon the guides of the attachment, that is the mechanism that runs parallel to the ways of the late.
Does anyone have an educated guess as to how much pressure would be exerted upon these guides during a taper cut?
I know it's a very general question and I'm not trying to be vague. Lets say taking a .020 cut in cold rolled steel. There has to be some pressure against the guide mechanism. I guesstimate about maybe 800 to 1200 pounds would be a safe bet. I understand that on one side of the piece being tapered it would be pushing, on the other side it would be pulling.
I wouldn't guess it would be much more tho..but then again I may be wrong.
Any and all help will be greatly appreciated. If I get this thing working I'll be glad to supply a drawing for others to build one from.
