- Apr 23, 2013
- 1,003
I have been making my own expanding collets for 50 some years. This one has the Logan spindle taper. It has a bushing for the back end of the spindle and has a 1/2 13 allthread rod with a tapped 1/4 inch thread in one end . I use a 1/4 shcs with a 15 degree taper formed on it to tighten and expand tha collet that is threaded into the Logan tapered collet. I slit the collets on my band saw. The expanding part can be recut and reused many times. This one is tightened with a nut and a wrench
I also made one with a shorter length of allthread that has a 5c collet thread that will work with a lever collet set up.
https://photos.app.goo.gl/UAtILpRPA5UqRIWa2
