    Dismiss Notice
HF Lathe chucks/jaws?
Discussion in 'HARBOR FREIGHT, CENTRAL MACHINERY & BUSY BEE' started by awaqa909, Apr 9, 2017.
  1. awaqa909
    awaqa909 United States Iron Registered Member
    4
    3
    City:
    Hutto
    State:
    Texas
    -Return to Top-
    I've looked up and down their website and at the manual for their 7x12 lathe and can't seem to find this info. I'm looking to find out if the chuck is self centering or independent? Also if jaws are replaceable? At work the cnc lathe has a petal for the jaws and its always centered. Also the guys who setup the lathes have racks filled with jaws. Is it normal to go though so many jaws? I know on the mills with the lathe chuck on the table, the jaws are taken decent care of. They're also different styles of chucks. (perhaps the difference of manual and pedal operation)
    Also while reading the manual I noticed the work tolerance is .005" What does this mean? Is it the work the machine can produce, or the work the machine is made out of?
    Thanks,
    Awaqa909
  2. Tozguy
    Tozguy Active User H-M Supporter-Premium
    625
    113
    City:
    Drummondville
    State:
    Province du Quebec
    -Return to Top-
    From the picture on the HF website, the 3 jaw chuck on the 7x12 is self entering.
    The jaws are replaceable, a different set can be required for different sized work. The jaws are not reversible because of the curvature of the grooves that engage the scroll. Page 9 of the manual shows 2 sets of jaws, one internal the other external.
    Re the 'work' tolerance of .005'' it must refer to what the machine can produce but it is risky business to interpret someone else' statements.
  3. tweinke
    tweinke United States Active User H-M Supporter-Premium
    209
    43
    City:
    Fairmont
    State:
    Minnesota
    -Return to Top-
  4. darkzero
    darkzero Global Moderator Staff Member H-M Supporter-Premium
    1,076
    113
    USA
    City:
    Los Angeles
    State:
    California
    -Return to Top-
    3-jaw chucks are pretty much always self centering/scroll chucks. If they do have an independent 3-jaw it must be for some specialized application, I've never seen one.
    Technically you can replace single piece jaws but it's not that simple. Chuck jaws are usually ground for a specific chuck body (slots & gripping surfaces). Higher end chucks will have the jaws & slots numbered as well as the serial or identification number on the jaws that match the chuck body. You could aquire another set of jaws & they may or may not fit your chuck body. And they would have to be ground for runout.
    What you are seeing with the CNC lathe and all those jaws are probably top soft jaws for 2 piece jaws. On 2 piece jaws you can replace the top jaws with soft jaws (usually aluminum) & they are machined to fit a specific part.
Share This Page
