Hf 8x12 Mini-lathes Tailstock
DMLCV
Iron
Registered Member
Aug 26, 2016
17
Likes
6
#1
I ran into a problem and need to address it, first my tailstock seems to not want to center and I believe I need to disassemble it and clean it up and reinstall it. Looking for some input as I am new at these larger lathes does not fit the Surline class.
kingmt01
Active Member
Active Member
Apr 29, 2015
899
Likes
205
#2
Might need some more info to go off from here. Have you taken it off & wiped the grease from under it?
Could it just be flexing enough to make you believe it isn't centered?
DMLCV
Iron
Registered Member
Aug 26, 2016
17
Likes
6
#3
Just forward of the adjustment screws is a slot for a key, need to find out the part number, Mini Lathe HF 44589 8x12. I went to align the tailstock and with it not locked down I got movement front to back. The tailstock was pretty much locked up and a dead blow hammer did help out quite a bit. I did get it back together but could not find the key I am not sure if it was even in there to begin with. I looked at the parts break down but my tailstock is not shown....
kingmt01
Active Member
Active Member
Apr 29, 2015
899
Likes
205
#4
It's been a while since I've looked at my 7x but I think I remember something like your saying. Likely it's just a common key stock. Take it to the hardware & see if you can find a piece that will need driven in. If not measure it & look on eBay for the mm that fits.
