On the HF 8x12 Lathe - I am needing to keep the shaft of the Cogged Belt Pulley lubricated and found it was all clogged up inside, so not getting any oil. I am wondering, would I be better off to use a Moly Grease and forget the oiling (or is Moly first and oil continuously a good idea) ?
