- Mar 18, 2011
- 243
A while back I bought a used 2 1/4 - 8 TPI slotted faceplate for/from a southbend lathe to use in a project. I also bought a new threaded backplate adapter for a chuck with the same 2 1/4 - 8 TPI thread. Fast forward to getting around to project and now I have a problem. I made an adapter for the project and cut a 2 1/4 - 8 TPI thread and it works fine on the new adapter but will not go into either side of the South Bend used faceplate. I am guessing the threads got banged on both ends but I need to fix it. It looks like the best bet (although expensive) is to buy a tap and run it through the threads. I know you can "chase" a thread and I have done it before on external threads, but never even cut an internal thread. Is it possible to repair this with a trick I don't know of like using a threading tool as a scraper or some wierd thing?
Thoughts?
Thanks,
schemer
Thoughts?
Thanks,
schemer
