Help With A Hammond #4 Voltage
Ken..was thinking something was done in the past..no dust..no grease from fittings at bearings..has sealed bearings.dont see a way for grease to lube anything.the varnish on windings looked really good.even though motor is sealed didn't see how it could be so clean for age of machine..going to get back on grinder after finishing up my 10k gap bed lathe..thanks for your reply
You're far much better with the sealed bearings in the long run. You don't have to worry about contaminated grease getting to the bearings using the existing grease zerks. Even though the class of bearing may not be the same from the OEM, you'll never notice it in operation. Ken
Hello..ran motor today for about 20 minutes.runs very quietly.using my starrett speed indicator looks like motor rpm is right at 1800.. Almost 18 sweeps of dial in 60 seconds.guessing motor is set up for 1750 rpm.noticed motor has newer gray paint compaired to rest of grinder with several layers of paint.thanks for everybody's help.will post some pictures when I clean.repaint and get her going
Hello.finished rebuilding my 10k.back on grinder.wired in a 26uf capacitor on leg going to motor.hooked other two motor wires to 220.runs forward.off.reverse very smooth..but after 15 minutes motor started getting hot..do I need to wire in a capacitor in one of 220 legs?going to make a rotary converter soon but thinking it will run hot if I wire it like this one.i have a lot to learn about 3 phase ..any ideas? Thanks Phil
Would it be better to use jumper motor on converter motor instead of trying to start it with capacitor.remove capacitor I wired into grinder motor? Thanks
First thing, that is a big oilfield capacitor to have on the generated leg of you small motor. I would think a 15uf would be better. The other two legs, I wouldn't put any capacitors on it. Just direct current from L1 and L2. As for the motor getting hot, that is the nature of a totally enclosed motor like yours with out an external fan to cool it off. The motor is not designed for continuous duty as a TEFC motor is. So it means, you have to stop and let it cool off for a bit after using it for a length of time. The capacitor should not have an adverse affect on heat being generated. If you think it is, take it out of the running circuit and just use it in the starting circuit. Ken
Have almost finished cleaning grinder up.still have to make a table.after looking at many posts on 3 phase wiring have wired up grinder.forward-reverse work.turn switch to forward or reverse.turn on breaker.motor hums.hit start button.runs..maybe someone could look at pictures and see if it's correct and safe.have picked up couple contractors.would they be a better choice..thanks for your time..Phil
Hi Phil,
in picture 2, it appears that you have a jumper wire between pole 2 and pole 3- i think that's why you are getting a hum- the poles are shorted
remove the jumper wire
jumper powered Capisitor.removed.hummed but wouldn't run.hooked red wire to power.still hummed but did run.thanks for your response
just to be sure...
T4,T5,T6 are connected
T7 & T1 will get 1 leg of 230v
T8 & T2 will get 1 leg of 230v
T9 & T3 will get 1 leg of 230 or will be the generating leg and would get the momentary switch and start capacitor if single phase is supplied.
any pairing Tx could be used as the generating leg
