    Dismiss Notice
Help me wire my new motor to my old Lathe
Discussion in 'ELECTRICAL ISSUES - POWER YOUR MACHINES & SHOP' started by Rd2nowr, Mar 29, 2017.
  1. Rd2nowr
    Rd2nowr United States Iron Registered Member
    11
    3
    City:
    Samson
    State:
    Alabama
    -Return to Top-
    Hey Folks! I purchased a new Century C311 1/2 HP Farm Duty reversible motor for my 37' SB 9a. I have a Furnas R1A drum switch and would very much like to know how to wire all this up to run my lathe. Thanks for the help! Tim
  2. Rustrp
    Rustrp United States Active Member Active Member
    438
    63
    City:
    Sacramento
    State:
    California
    -Return to Top-
    It would help greatly to have the wiring diagrams for both. The drum switch will be wired into the circuit on the motor using the wires that indicate clockwise or counterclockwise direction of rotation. On the motor you have line voltage coming in which is one hot leg, a common and a ground. The diagram on the load side shows which wires would need to complete the drum circuit.
    Edit: The typical instructions/diagram show which wires are tied together for forward or reverse, so when you insert the switch into the circuit the wires are tied together inside the switch....and I better stop before this derails. I don't like giving poor electrical advise.
  3. markba633csi
    markba633csi United States Active Member Active Member
    315
    63
    City:
    Mountain View
    State:
    California
    -Return to Top-
    Agree with Rust, need diagrams of your motor- drum switches are pretty straightforward (or reverse LOL)
    Mark S.
    Rustrp likes this.
  4. Rd2nowr
    11
    3
    City:
    Samson
    State:
    Alabama
    -Return to Top-
    This is the diagram from the motor . The switch type and a picture of the inside of switch.
  5. Dave Paine
    Dave Paine United States Active Member Active Member
    144
    43
    City:
    Eastern PA
    State:
    Pennsylvania
    -Return to Top-
  6. Rustrp
    438
    63
    City:
    Sacramento
    State:
    California
    -Return to Top-
  7. Rd2nowr
    11
    3
    City:
    Samson
    State:
    Alabama
    -Return to Top-
    Thanks to all. I got it figured out. Tim
    Rustrp likes this.
  8. Rustrp
    438
    63
    City:
    Sacramento
    State:
    California
    -Return to Top-
    I meant to add to my comment with the link to I sent with the diagrams; I'm offering this tid-bit of helpful advice to anyone who's working through their electrical problems and are not sure about the correct connections. Add in-line fuse pigtails (pick them up at your local auto supply store) to your wires as you work through the problem and if the connections are wrong you will blow the fuse, and not damage the motor, switch, or worse, cause physical harm to yourself. When you have the connections correct, remove the inline fuses and save them for the next challenge.
    .....and it's good to hear you got it back online.
Share This Page
