Help Identifying This Brown & Sharpe Tool/fixture, Please.
TORQUIN
Mar 19, 2015
154
I picked this up the other day, as a possibility of using as an angle plate, but would like to know what it is and what it's used for before I do anything with it. Searching Google for the numbers has yielded nothing.
Thanks,
Chris
3366 looks to be a tilting vice.
920 could be a precision straight edge used to help set the vice angle.
Very Very Nice Score.
B&S calls that a #2 adjustable swivel vise. I just picked up a B& S model 2L surface grinder and it is shown in the 1946 operation and maintenance manual. Yours may be a different size, but it looks the same. The "No, 3367" is almost certainly a serial number, the s/n on my grinder in two places is in the same font and style and the main s/n is raised on a boss just like yours. 920 is likely the part number of the straightedge, like tertiaryjim said.
So do you think this is specifically for grinding, or grinding and milling? I am trying to hunt more info on it, including examples of setup, on Google now.
Thanks,
Chris
Yep, these smart folks here figured it out already. The very fine adjustable swivelling machine vise able to be tilted 45° each side of horizontal and fitted with 5-inch wide, 1-inch deep jaws in a hardened tool steel that could be opened to a maximum width of 2.75". Used on a surface grinder. The 920 is a b&s parallel.
Thanks,
Chris
I don't have enough knowledge to know what B & S had in mind for it, but in my playbook, wherever it can handle a job, it is welcome...
