Help! I Keep Magnetizing Tools!
rwm
Robert
H-M Lifetime Diamond Member
Mar 25, 2013
4,606
Somehow I am managing to magnetize some of my tools. I have no idea how. First I magnetized my digital calipers which was really annoying since I would get chips stuck between the blades and not get a consistent zero. So I finally bought a new one! Now I have magnetized my chuck key. Really annoying when turning steel. I do not have any magnets on my lathe except for the tach which is enclosed in the housing and the key has never been near that.
1. Why is this happening? My wife says it is my magnetic personality; I know that's wrong.
2. Is there a good way to demagnetize these?
3. Do you own a commercial demagnetizer that you like? If so what brand.
4. Any other recommendations?
I'm seriously considering making a Titanium key....
Robert
I have this issue when I cut tool steel with a cobalt cutter on the lathe. Somehow or another, this sets up some sort of magnetic field and everything starts to stick. Any tool that touches that work piece will also become magnetic - really irritating. So much so that I bought an old bulk tape demagnetizer on ebay to deal with the problem. Works really well. I also demagnetize the work piece once I get it out of the chuck.
I purchased ( less than $5.00) a sewing notions demag, for needles, etc. I've used it to demag needle nosed pliers and other similar tools. I haven't tried it on something as large as a hammer, but everything I've tried has been demagnetized.
Thanks guys. I ordered a Demagnetizer from Shars like the one above. I will let you know how it works. I still might make a Ti lathe key....
Robert
I have the little cube thing demagnetizer and the metal brick looking thing demagnetizer. But they do not remove all the magnetism. Small metal filings will still stick to whatever I’m trying to demag. I like the demagnetizer I have pictured below. It will COMPLETELY demag. It is used in the watch repair trade. Does not have a very big working area and the parts to demag CAN NOT MOVE during the demag. But boy does it do a good job!...Dave
So why do these items get magnetized anyway? I really don't understand the chuck key.
Robert
I don't remember my physics very good but there is something about two steels continuously rubbing against each other, like a cutting tool, can create very small amounts of magnetism. I've also seen in steel centers where steel bars and such are handled, they use crane magnets to lift and handle the steel bars. And if the guy running the crane has the magnet turned to full power, it will magnetize bars, big and small. And it's no fun cutting on a magnetized bar of iron! Chip control is awful!
It has been a while since I studied this in chemistry class but magnetism occurs when most of the outer electrons in iron get arranged so they're aligned the same way either by induction from nearby magnetic fields or, in this case, by mechanical action. I think that only iron & most of its alloys have the ability to retain this alignment. A handy way to demagnetize tools & parts is to use a bulk cassette tape demagnetizer. Simply turn the demagnetizer on, hold the base about 1/2 inch from a magnetized object & move it around with the demagger still on while moving it away. Turn the demagger off after it's about 4-6 inches away from any steel objects. Hope this helps.
