- Oct 21, 2014
- 2,156
Obtaining a new to me lathe, but need backing plate for chucks. I know that cast is supposed to be best for backing plates, but will normal steel work.
Second part of the question. what is the best way to start the new backing plate, when the main thing I have is a face plate.
One thought is to drill 4 holes in the blank, Then mount it to the face plate. and indicate it as best possible.
Then bore out the center hole, face off the area for mounting, then start threading.
Would it be better to space it off of the face plate so that you do not hit the face plate when boring and threading. I figure once it is treaded, then mount it on the spindle and finish turning it to size and face it off properly. Then turn it around and finish off the back.
Hopefully the last part, how to figure out what size whole to bore for a 52mm x 8 tpi thread.
New to doing internal threading. have done some external but have not done internal watching some you tube but that is it.
