Hi all,
I have a 1970 powermatic 1150 drill press, and a gorton 8-1/2D mill that sit more or less side-by-side. I have a 10" rotary table that is too heavy and unwieldy to be easily lugged onto the mill when needed. My shop space is very limited (surprise), so I'm wondering if i could leave the rotary on the drill press table semi-permanently, and just swing it over to slide into the mill table as needed?
Or would that likely warp the cast iron of the drill press table or its bracket over time? It's a standard (non-production, non-tilting) table on a 3" column.
I haven't weighed the rotary, but it's likely somewhere between 100 and 150lbs.
Thanks in advance,
Lee
Sent from my SM-N920T using Tapatalk
Thanks in advance,
Lee
