    Dismiss Notice
[Mill] Heald horizontal mill, recently acquired
Discussion in 'ANTIQUE & VINTAGE MACHINERY' started by 100LL, May 19, 2017.
  1. 100LL
    100LL Active Member Active Member
    15
    8
    City:
    Houston
    State:
    Texas
    -Return to Top-
    I just picked up a Heald horizontal milling machine and got it home. Been cleaning it up and had a few questions.
    Anyone familiar with these? It came with a little bit of paperwork and I've found some stuff online. But I have a few questions beyond what I can find in the sales and parts literature.
  2. mzayd3
    mzayd3 Active User Active Member
    157
    43
    City:
    Mayfield Heights
    State:
    Ohio
    -Return to Top-
    I have one with no vertical head though. What questions do you have?
  3. 100LL
    15
    8
    City:
    Houston
    State:
    Texas
    -Return to Top-
    Well, just my luck, first question I have is how to best remove the vertical head attachment. It looks to weigh a hundred pounds and if I loosen up the bolts I'm worried about it falling or some other disaster...I'm just not sure how it attaches on there exactly and don't want to mess it up so I'm looking for the removal/install procedures.
    I'm wanting to take it off so I can repack the spindle bearing (which is my second question), and generally clean/grease everything.
    Third question has to do with the Arbor. I have only one, and it doesn't have a keyway. My spindle is the 9 B&S version. I'm wanting to either find or make some more arbors.
    I need to replace the belts too...and that's another question although I could probably figure that one out.
  4. mzayd3
    157
    43
    City:
    Mayfield Heights
    State:
    Ohio
    -Return to Top-
    Well, the spindle belts were originally split and glued together after install. I used b size link belt, I think it's 80" circumference.
    You might not need a keyway on the arbor. Mine has one and I use it, but I have heard of others not using one at all with no issues.
    Here is a good resource for some of your other questions.
    http://vintagemachinery.org/mfgIndex/detail.aspx?id=5086&tab=3
    FOMOGO likes this.
  5. Charles Spencer
    Charles Spencer Active User H-M Supporter-Premium
    963
    93
    City:
    Worcester
    State:
    Massachusetts
    -Return to Top-
    Wait a minute. There was a Heald in Missouri? Heald machinery had a large manufacturing facility in Worcester for decades.
    FOMOGO likes this.
  6. fradish
    fradish United States Active Member Active Member
    69
    18
    City:
    Harmony
    State:
    Pennsylvania
    -Return to Top-
    Let me start by saying I do not have one of these mills, but can you lower the
    head down close to the table, then make a wooden cradle of some sort that
    securely holds onto the head? Then you can use your Z axis to take up
    the weight of the head and the Y axis to slowly move the head away from the
    column once you get your bolts loosened.
    There is a guy on YouTube who goes by "This Old Tony" who has a Schaublin mill
    and he put a dowel in his vertical head collet. He then used a V block to clamp
    the dowel into his vise to support the head as he removed it from the mill. I have
    no idea how the weight of his mill head compares to yours, whether or not this
    could work for you...
    FOMOGO, brino and rdean like this.
  7. 100LL
    15
    8
    City:
    Houston
    State:
    Texas
    -Return to Top-
    That's a brilliant idea! thank you, I hadn't thought of that but it makes perfect sense.
    I was about to build a little gantry structure on wheels.
  8. Martin W
    Martin W Canada H-M Supporter - Premium Content H-M Supporter-Premium
    165
    43
    City:
    Welland
    State:
    Ontario
    -Return to Top-
    Brown and Sharp #9 arbours are out there but hard to find. Watch EBay. I have made a few end mill holders for my Wells Index mill. It has a B&S #9 spindle.
    Nice looking mill by the way.
    Martin
    Ulma Doctor likes this.
  9. Charles Spencer
    963
    93
    City:
    Worcester
    State:
    Massachusetts
    -Return to Top-
  10. brino
    brino Active User H-M Supporter-Premium
    2,298
    113
    City:
    Almonte
    State:
    Ontario
    -Return to Top-
    Hi Tyler,
    I have never seen one of those mills 'til now.
    I have no advice, but just wanted to say what a great looking machine it is.
    Your table looks new.
    Any idea when it was made?
    Thanks for sharing the photos.
    -brino
  11. Ulma Doctor
    Ulma Doctor Infinitely Curious Active Member
    3,047
    113
    Ethereal Plane
    City:
    Tracy
    State:
    California
    -Return to Top-
    beautiful milling machine
    :drool::drool::drool:
    Martin W and brino like this.
  12. 100LL
    15
    8
    City:
    Houston
    State:
    Texas
    -Return to Top-
    Thanks. I'm very happy to have found this old quality machine and give it a home in my shop.
    Since getting it home I've spent time cleaning it up. These pictures are from the seller's shop where it had accumulated a little rust on some of the hand-wheels and handles/knobs. All fixed up now.
    The table appears original. The previous owner took very good care of his machines and for that I'm lucky (and also paid a premium). But who knows, the machine is from the 1950's so a new table could have happened sometime since then.
    The vertical head has 4 grease zerks on it. Any recommendations for grease? I need to squeeze some in there.
Share This Page
