- Jul 26, 2014
- 93
I have just purchase a used lathe that that will I hope, replace my 7"x 12" lathe.
My new lathe at least to me is an older 16" x 40" TA Shing lathe made in Taiwan about thirty years ago.
It was moved to my shop last night, what a job as it weighs in at around 2,000 pounds. A bit of a difference from my Seig 2 lathe.
This lathe came from a local machine shop where it was used occasionally in their tool shop area.
Basically there was or is no tooling with the purchasing, it has a 8" three jaw chuck, a huge spanner type of wrench to lock the locking collar in place
for the chuck, a live center and a MT4 key-less drill chuck for the tail stock.
Ok, now let me start with a few questions?
My 7 x12 lathe has been adapted to hold a AXA-100 QCTP holder, I have now around 10 holders for this tool with mostly small tooling (5/16") HSS and carbide
cutters. I also have a set of 10mm carbide insert tooling.
Is it reasonable and or advisable to move this tool post and tooling to the new lathe or should I acquire a new BXA or larger unit to use as my base for holders and cutters.
Currently the lathe comes with a large Lantern type tool post but I want to upgrade to a QCTP.
With this size of lathe what size of cutting tools should I purchase in the future, I realize that the QCTP that I settle on will set the maximum size I can use..
I also have a problem with the 8" three Jaw chuck, it works very well, however the problem is that it did not come with a set of outside jaws only the inside jaws.
What is the best way to try and find a set of jaws that will work?
The lathe is powered by a 3HP 3-Phase motor and as I only have 220 volt single phase available in my shop I intend on buying a 3KW Variable Frequency Drive Inverter which is supposedly
capable of running a 4HP motor. I have been advise that it is wise to allow 25% or more of overhead with these electrical devises.
I also intend on purchasing a new 4-Jaw independent chuck for the lathe, my question is what size should I buy? The 8 inch chuck that is on the lathe sure looks small.
Well that is enough questions for the thank you in advance for your input!
