Harbor Freight band saw modifications
Mark_f
Jan 16, 2020
5
I know there are tons of band saw modifications and post about them on here and everywhere else. After tuning up my old 4 x 6 band saw and getting it to be the metal eating beast it should be, I decided to do some upgrades. I searched the net and found enough upgrade sites and write ups to keep me reading for a month. After hours of looking ( and most of them are listed somewhere on this site also) I picked out the ones I thought were best and started implementing them on my saw. I thought maybe a write up with all the mods done to one saw in one write up would be of interest to anyone who is new to them or is thinking of improving their " saw kit" they purchased. I did a thread on here about setting the tension, choosing the blade, the feed and speed of the blade. that all makes the saw cut. these mods make it a pleasure to use.
My saw is very old, more than twenty five years. The first thing I did was strip the deck by removing the fences height bolt and cleaning the deck. mine was rusty and pitted so I sanded the deck with 60 grit on an orbital sander being sure to keep the pad flat. the next step was to scrape any high areas of the cast iron and then polish the deck with a coarse wet stone. I checked the deck for flatness and it is now better than when it was new.
decked table.jpg This is the finished deck. Notice I also drilled and tapped three 3/8-16 holes next to the blade area. these are to use my mill clamps for sawing small pieces the vise can't hold. I found this mod on several web sites and it will be a big help to me.
precision bushing3.jpg I made a precision brass bushing to fit the 3/8-16 bolt that holds the pivot point of the fence. I drilled the hole in the fence out to 1/2 inch and made the bushing a light press in the fence and the bolt a snug sliding fit in the bushing.
precision bushing.jpg This eliminates any excess movement at this point which is going to help when setting angles and squareness to the blade. there was some play in here from the factory. it wasn't even close to a good fit. now it is tight.
Setting fence square to blade.jpg Next , I used a precision square to set the fence square to the blade and locked the fence in this position.
saw table modifications 2.jpg I made a block with along 1/4-20 set screw and bolted it to the table using two 1/4-20 socket head cap screws. This adjustment holds the blade square so when you move the fence to cut an angle, just move it back to the stop and it is square again. Saves a lot of time squaring up the fence. this mod was selected from a web site also. this is also why I put the bushing in the pivot point. slop in the pivot point messes up the squareness when returning the fence to "home". the busing eliminates the problem.
saw table modifications.jpg Another modification I saw on a web site I liked was to make a "high" bolt with a Tommy bar and a flanged bushing for the slot in the fence. the 5/16-18 bolt that holds the movable jaw is sloppy fit at best. so , I flied the sides of the slot straight and made a bushing much like for the pivot point. now the movable jaw is a smoother and better fit. it is also easy to tighten and loosen with the Tommy bar. I also drilled and taped the movable jaw for a 3/8-16 threaded rod with a knob on one end. this jack bar holds the vise square when sawing short parts.
close up of handle extension.jpg Sometimes I like to rest the saw blade on my work to measure or set up for clamping and then I have a difficult time accessing the crank for the vise. I made an extension for the screw shaft to move the handle out where it is easy to get to when the saw is down. I found the handle did not want to work smoothly. this has always been a problem. the reason was the casting has an angle where the shaft comes out and the casting is not square to the shaft. )I suspect this is a draft angle to let the casting come out of the mold easier:dunno: ).
Grind casting flat.jpg Here you can see where I used my angle grinder to grind the casting flat in this area. the screw works much smoother now.
modifications done today.jpg This photo is a review of the modifications don today on my saw. All these mods only took a few hours. I was done in one afternoon.
Next on the schedule is a hydraulic down feed cylinder to replace the garage door spring the manufacturer uses. those parts are ordered and I will add that to this thread when they arrive.
I also have ordered a link v belt for the saw. I tried the belt from my mill on it and "what a difference". The saw runs smoother and quieter, so I ordered a new link belt for it at a cost of $20. the rest of the modifications were free as I used items I had on hand and from my scrap box.
I have plans for a chip pan to catch the chips and a table extension at the out feed area to make "special" sawing setups easier. These will be added as I do them also. So keep watching this space.
With just a little work you can make your cheap ......umm.....inexpensive saw into a really high quality piece of tooling.
Mark Frazier
decked table.jpg precision bushing3.jpg precision bushing2.jpg precision bushing.jpg Setting fence square to blade.jpg saw table modifications 2.jpg saw table modifications.jpg close up of handle extension.jpg Grind casting flat.jpg modifications done today.jpg
Holy Moly Mark
After seeing that I'm gonna drop mine off the next time I pass through Pa. That's a really nice rework !
dickr
Mark
Love my old HF band saw.
Kinda reminds me of a old 32 Ford Hot Rod
No idea how old it is, found it in the trash years ago, & it has been working reasonably well.
Looking forward to the ideas that will show up here ..especially the down pressure controll
Subscribed
ed
Thank you Mark good job on the upgrades. Please post when you get the down pressure feed done thomas s
Looks like everyone wants the down feed control. Well the hydraulic cylinders are too darn expensive. I been looking all over the net and cheapest thing I found so far is McMaster Carr for forty bucks for the cylinder. I was about to order it and decided to try to make one first. ( You guys will probably like that). If It works this control will cost nothin as I think there is enough stuff in the scrap box.
So.... :rubbinghands: ... i going to try to make the whole thing. Cylinder, check valve, and needle valve. I already got a plan. I just hope it comes together.
Mark Frazier
Mark, I have no doubt that you will build a beautiful down stroke control system.
For the others reading who are lazy like me and don't want to take the time to build our own. Hydraulic cylinders are not needed. Any air cylinder in the +/- 1 inch or so range would work fine on a 4x6 saw. I'm using a 2 inch, salvaged, air cylinder on my much larger Wells. The system is filled with hydraulic oil. I did build the bracket for the flow control.:whistle:
Yea, I know an air cylinder will work cause that was what I was going to order for forty bucks. The hydraulic cylinder is way expensive. But since I have the material and maybe the ability, I gonna give it a shot to make it. I can always spend the money if it doesn't work.....lol
Mark Frazier
The spring on my 4x6 saw has been working fine for cutting rounds, but probably next year I will need to cut some square tube so I've been exploring the hydraulic down-feed mod. Like you've noticed, if you buy everything new in can get kinda expensive so I'm hoping to score a cheap cylinder and other parts somewhere. I'll be watching for your DIY version as a Plan B.
Are you going to add a bypass for the needle valve? Everyone uses a one way valve so you can lift the saw, but I was planning on adding a button valve bypass so you can lower the saw quickly without opening the needle valve.
I hadn't thought of that, but it is a good idea. I think I will use a ball valve for that so as not to be able to accidentally lower the saw though. Thanks for the idea.
Mark Frazier
