- May 14, 2013
- 237
I have a King 10x22 lathe that started making some noises that I did not like. Upon further investigation I determined that the 104 tooth gear somehow has some partial tooth breakage? All of which are to one edge, just to keep going I reversed the gears orientation, and all seems fine and quiet. My question to those in the know, Will the change gears on a G0602 be standard (DP) or metric( Module) as I am considering buying the needed cutter to make a replacement. If metric from what I have been able to cipher it will be a 106mm diameter , 1.0 module #7 cutter for 55-134 teeth or if a "standard " involute gear 8(DP) and #2 55-134 tooth cutter I also will need to find the proper pressure angle, 14 1/2 deg. or 20. The module cutters I found listed are only the 20 deg. pressure angle. Any help / insight is appreciated . Thanks in advance.
