Recently received my Grizzly G0752 which is the variable speed version of the G0602. Tried to familiarize myself with changing the v belt for speed and swapping out the gears for threading. I was able to remove the gears but there are two of them that are held by what seems like an adapter in the middle. It holds the big gear together with the small one. Is there an easy way to remove that adapter other than purchasing a punch press?
2nd Question, I followed the instructions to pop out the E-clips and cap screw. After removing the E-clip on one of them, there's a black round plastic piece that still holding the gears together. How do you remove that? The other set of gears with the larger e-clip had a square plastic piece holding it together so that was easily taken off with a wrench.
Appreciate the help
- newbie
Appreciate the help
- newbie
