A few things if you do that:Good question. I have exposed joists in my shop and I thought I might be able to lift it up off of it.
Couldn't you just rotate the nut on the bottom for the QCTP?Looks great! Now all you have to do is run power, break it in, come up with a list of projects, start drooling at miscellaneous tooling, etc. etc. etc.
There's a thread in this forum on my set up experiences. My biggest annoyance was the position of the QCTP locking lever - setting over top your work when it's tight. I (surface) ground the plates on the piston style pressure plates to change the handle position...
Bruce
Hi Steve,Couldn't you just rotate the nut on the bottom for the QCTP?
Steve Shannon
Yeah, that sure was annoying. My solution was just to buy an Aloris. Not a fan of the cheap piston style tool posts.My biggest annoyance was the position of the QCTP locking lever - setting over top your work when it's tight. I (surface) ground the plates on the piston style pressure plates to change the handle position...
