    Dismiss Notice
Grizzly G0704 Cnc Conversion
Discussion in 'MACHINE BUILD LOGS' started by cozmogeek, Jan 9, 2016.
  1. cozmogeek
    cozmogeek United States Active Member Active Member
    17
    8
    City:
    kent
    State:
    Washington
    -Return to Top-
    I got a grizzly g0704 yesterday and am planning to convert it to cnc as soon as I can. I don't have any metal machining experience so this should be very interesting. Stay tuned for pictures and videos.
    I got Hoss' conversion info and hope that will be enough for me to figure this out.
    3D printed temporary stepper mounts
    willlie likes this.
  2. JimDawson
    JimDawson Global Moderator Staff Member Director
    3,840
    113
    City:
    Sandy
    State:
    Oregon
    -Return to Top-
    Should be in interesting build, I'll be watching.:encourage:
  3. mattthemuppet
    mattthemuppet Active User Active Member
    685
    113
    City:
    Walla Walla
    State:
    Washington
    -Return to Top-
    ooh, that's really cool using 3D printing to make some of the parts!
  4. TomS
    TomS Active User H-M Supporter-Premium
    433
    83
    City:
    Redding
    State:
    California
    -Return to Top-
    I see the word "temporary" in your post. Are you using these mounts for set up?
    Tom S.
  5. cozmogeek
    17
    8
    City:
    kent
    State:
    Washington
    -Return to Top-
    The theory is to use the plastic mounts to get it cnc'd faster then use it to make the metal mounts
  6. TomS
    433
    83
    City:
    Redding
    State:
    California
    -Return to Top-
    I hear what you are saying but will the plastic mounts be rigid enough? I'd be concerned that the mounts will distort when you load the motors during a cut. A couple of implications would be inaccurate parts and possible damage to your motor couplings and/or ball screws.
    Just my thoughts. You may be successful. Let us know how it turns out.
    Tom S.
  7. lcvette
    lcvette United States Swarf Registered Member
    0
    1
    City:
    Rocky Point
    State:
    North Carolina
    -Return to Top-
    I don't think it will be a problem unless he is trying to take really heavy cuts. Should be plenty fine for making the parts out of metal for the conversion which won't need super critical tolerance.
    Good luck, its a long arduous journey but worth it in the end!!
    Sent from my XT1080 using Tapatalk
  8. cozmogeek
    17
    8
    City:
    kent
    State:
    Washington
    -Return to Top-
    Well I haven't had much time to mess with this thing yet since I've been doing some home remodeling however I just grabbed this little clip.
    Getting excited now!
    brav65, JimDawson and jkcrum like this.
  9. TomS
    433
    83
    City:
    Redding
    State:
    California
    -Return to Top-
    Looking good. Keep us posted on your progress.
    Tom S.
  10. jkcrum
    jkcrum United States Iron Registered Member
    5
    3
    City:
    Leavenworth
    State:
    Washington
    -Return to Top-
    Just curious, if your Grizzly has acme screws like mine, will you convert those to ball screw if going to CNC? Or can CNC programs take the slack into account and compensate to get the accuracy you want?
  11. JimDawson
    3,840
    113
    City:
    Sandy
    State:
    Oregon
    -Return to Top-
    Under a few conditions backlash compensation works, but not many. Cutting a circle for instance, it won't work. It will work for doing a hole pattern, but in general it will not work when continuous cutting. The only real way to get accuracy is to have zero backlash.
    rdean and jkcrum like this.
  12. cozmogeek
    17
    8
    City:
    kent
    State:
    Washington
    -Return to Top-
    The ballscrew upgrade is really expensive. I want to see how it does with the leadscrews first.
  13. TomS
    433
    83
    City:
    Redding
    State:
    California
    -Return to Top-
    Look at what Linear Motion has to offer on eBay. Their pricing for ball screws and nuts is very reasonable. I spent about $125 for three pre-machined ball screws with nuts, and three each fixed and floating bearing blocks about a year ago when I converted a PM-932. The contact person is Chai and his customer service is very good.
    Tom S.
  14. cozmogeek
    17
    8
    City:
    kent
    State:
    Washington
    -Return to Top-
    X-axis motor is attached!
    JimDawson likes this.
  15. brav65
    brav65 Active User H-M Supporter-Premium
    413
    63
    City:
    Phoenix
    State:
    Arizona
    -Return to Top-
    +1 on linear motion and Chai. I got 4 ballscrews and nuts along with a spindle motor and linear bearings. Good guy, and if you buy direct he will give you an additional 10% over eBay prices.
  16. cozmogeek
    17
    8
    City:
    kent
    State:
    Washington
    -Return to Top-
    Thanks for the heads up about the discount. I'll have to look into it soon.
  17. brav65
    413
    63
    City:
    Phoenix
    State:
    Arizona
    -Return to Top-
    You can give him the specs for the coupling interface you are using as well as the bearing blocks and they will turn the ends for you. I just sent a hand drawn sketch. His email is linearmotionbearings2008@aliyun.com
    I have no connection with them, just a happy customer.
  18. cozmogeek
    17
    8
    City:
    kent
    State:
    Washington
    -Return to Top-
    I got the X and Y done and everything wired on Monday since it was a holiday.
    I just got my Z axis done. I used the 3d printed direct drive nema 23 mount. I used linuxcnc and the jog keys on the keyboard (arrows) to make those aluminum standoffs for the Z motor. That's the first thing i've ever milled...yay!
    Now I need to spend some time getting linuxcnc configured. I got a USB pendant too that I need to get setup.
    TomS likes this.
  19. cozmogeek
    17
    8
    City:
    kent
    State:
    Washington
    -Return to Top-
    Steve Shannon likes this.
  20. cozmogeek
    17
    8
    City:
    kent
    State:
    Washington
    -Return to Top-
    I have made some more progress on this. Last week I ordered the ballscrews.
    I tried tracing text with a 1/8" endmill and the results are pretty ugly:
    You can see the backlash in the results. When drawing the O and D the start and end of the letter don't line up. This was before I realized that the bearing wasn't seated all the way so I had a ton of backlash. After I cut this I measured and it was .04" (LOL).. I tightened it up correctly and got it down to .003"
    So then I setup the backlash compensation and tried an engrave operation instead and it was much better other than my board not being straight.
    Over the weekend I made the motor mount standoffs and the X axis mount (manually using the jog controls on the keyboard):
    Tonight I plan to replace the 3d printed X mount with this new one.
    The Z axis mount is different for the ballscrews than the leadscrew version so I'll have to wait for those parts to arrive before I can replace it. I'm not sure about Y yet. It is more complicated since it has the spacer with the holes for the bearings.
    TomS and JimDawson like this.
  21. cozmogeek
    17
    8
    City:
    kent
    State:
    Washington
    -Return to Top-
    Got my ballscrews today. This is going to be a lot of work to change to these.
    rdean likes this.
  22. MontanaAardvark
    MontanaAardvark United States H-M Supporter - Premium Content H-M Supporter-Premium
    63
    28
    Just South of the Kennedy Space Center
    City:
    Melbourne
    State:
    Florida
    -Return to Top-
    I just posted about a conversion project like yours a few days ago (last Saturday?) on the Grizzly board. I guess I should have put it here.
    I'm also doing the phase 1 from Hoss, with the big difference being I cut all the metal parts first. I don't have a 3D printer, but I have a CNC Sherline(/A2Z CNC) system. I cut everything on that.
    But your motors, breakout board from CNC4PC and the rest sure look very familiar. Tonight I was going over how to wire up everything so the limit switches and the Big Red Switch work with it. And I think I'm on the way to eBay to look at those ballscrews.
    My Sherline has the A2Z upgraded XY base. The leadscrews are 4TPI, Teflon coated Kerk screws. They do have a few thou of backlash, though. I was also thinking of looking for other Kerk products.
    Bob
  23. MontanaAardvark
    63
    28
    City:
    Melbourne
    State:
    Florida
    -Return to Top-
    Can someone give me a link to Linear Motion on eBay?
    When I searched for that name on eBay, there was no result. I eventually made it one word, and now there are four. None of them have anything up for sale.
    Needless to say, I'm having a bit of confusion.
    linearmotion ( Feedback Score Of 80 iconBlueStar_25x25.gif )
    2 years 3 months AZ,United States
    Close matches:
    Member id linear-motion ( Feedback Score Of 10 iconYellowStar_25x25.gif )
    8 years 6 months Germany
    Member id linearmotion01 ( Feedback Score Of 882 iconPurpleStar_25x25.gif )
    11 years 0 months Germany
    Member id linear_motion ( Feedback Score Of 63 iconBlueStar_25x25.gif )
    9 years 6 months MN,United States
    From what was said, I assumed if they weren't in the US, they'd be in China or somewhere else in the Orient.
    Thanks,
    Bob
  24. sbx
    sbx United States Active Member Active Member
    42
    18
    City:
    Santa Barbara
    State:
    California
    -Return to Top-
    Bob - Try Linearmotion2008. I think the guy's name is Chai. And I do think he was in China. Just based on the research I've done for my PM25 (research ongoing). Not an endorsement, just what I remember. Hope that helps.
  25. MontanaAardvark
    63
    28
    City:
    Melbourne
    State:
    Florida
    -Return to Top-
    Thanks for the suggestion, but that doesn't show up either. I think I tried every variation of spacing.
    Maybe they've closed their eBay account?
    Edit to add: I just sent an email to that address farther up the thread. I'll see if I get anything back.
    Edit yet again to add: Hoss' DVD says the name on eBay is linearmotionbearings. That doesn't show up on eBay either.
  26. cozmogeek
    17
    8
    City:
    kent
    State:
    Washington
    -Return to Top-
    Automation technologies sells the ballscrews as well. They order them to hoss spec from chai.
  27. brav65
    413
    63
    City:
    Phoenix
    State:
    Arizona
    -Return to Top-
    They are listed under linearmotionbearings2008 and have at least 100 listings. I posted Chai's email address to which you sent the email. Keep in mind the time difference when waiting for a response.
  28. jbolt
    jbolt United States Active User H-M Supporter-Premium
    928
    113
    City:
    Mountain View
    State:
    California
    -Return to Top-
    This is the email address I use for Chai. cgxfred@aliyun.com
    I have dealt with him several times and have always been very pleased with his service.
  29. MontanaAardvark
    63
    28
    City:
    Melbourne
    State:
    Florida
    -Return to Top-
    I just heard back with an informative email, and their store is:
    http://stores.ebay.com/linearmotionbearings
    I'm not sure why it wasn't showing up in my searches, but maybe because I was searching by seller and not by eBay Stores?
    The next thing on my list is to build my controller box, and maybe a computer. My Sherline is running Mach3 on a 1 GHz XP box that's cut off from the outside world, with nothing on it except Mach3. Not sure what else I can put together in a hurry.
    But before that, I've got to finish painting the kitchen!
    Bob
  30. cozmogeek
    17
    8
    City:
    kent
    State:
    Washington
    -Return to Top-
    That's funny. I was remodeling a bathroom when I first started this project which slowed me down quite a bit. Gotta keep the wife happy right?!
Share This Page
