    Dismiss Notice
Grizzly G0619 Column Stiffening
Discussion in 'GRIZZLY INDUSTRIAL INC.' started by RodSME, Mar 29, 2017.
  1. RodSME
    RodSME United States Iron Registered Member
    21
    3
    City:
    Cape Coral
    State:
    Florida
    -Return to Top-
    DAT510 asked if I would post info on my project to stiffen the column of the Grizzly G0619 in torsion. Here it is.
    RodSME
  2. DAT510
    DAT510 United States H-M Supporter - Premium Content H-M Supporter-Premium
    90
    28
    City:
    San Mateo
    State:
    California
    -Return to Top-
    Great work and analysis! I'll definitely look at upgrading my mills with your mods. Thanks.
  3. hman
    hman Active User H-M Supporter-Premium
    939
    113
    Tempe. AZ -and- Corvallis, OR
    City:
    Tempe
    State:
    Arizona
    -Return to Top-
    Nice analysis! I think I may have something additional to contribute. I recall learning, many years ago, that a "closed section" is extremely good at resisting torque. The column of your mill is open at the back, thus not a closed section. Just for fun, you should try modeling the addition of a more-or-less continuous plate to attached to the back of the column and closing it. Maybe something like your rear plate, but going all the way to the top of the column. Shouldn't have to be ½" thick. ¼" would probably work wonders.
    Disclaimer: I don't have an 0619 myself, and don't know what interferences or complications might crop up if a plate is added to the entire back of the column. If nothing else, you'd have to modify the arm that holds your DRO read head. All I can go by is what I see in your Picture 2.
    Since you've added the internal bars, it should be easy to add a full cover (or even a plate to cover above the existing rear plate) by screwing it to the internal bars. Without them, adding a full cover would require drilling & tapping into the back edges of the casting. But if you want to model the idea of just adding a full cover without the internal bars, that might be of interest to others who have the same mill.
    Hope this helps!
    Rustrp likes this.
  4. Rustrp
    Rustrp United States Active Member Active Member
    437
    63
    City:
    Sacramento
    State:
    California
    -Return to Top-
    Connecting the two sides would improve the strength a lot. It would be beneficial to have the rear plate and anything added be a complete unit, connected by whatever means you may have. If the rear plate and the additional piece are not connected strength will still be gained.
    PS. Rod, if I were doing this project from the beginning, I would plan on inserting a channel shape into the back of the column and fastening it in as you have done with the machine screws. The deflection you are getting is in the column above the rear plate you attached.
    hman likes this.
  5. DAT510
    90
    28
    City:
    San Mateo
    State:
    California
    -Return to Top-
    The G0619 lifts the head from the back, using a leadscrew inside the column. This prevents the back from being completely enclosed.
    brino and Rustrp like this.
  6. Rustrp
    437
    63
    City:
    Sacramento
    State:
    California
    -Return to Top-
    So anything flush.....Nah, I see it now, plus I can see the stiffening ribs cast into the front. This limits the amount that can be done. There is one more option but the effort is limited by the resulting change so it's best to work it as it is.
    Edit: With a plate at the top and a C-shaped long plate connecting the top and bottom plates you might get a little more rigidity. Something 1/2" thick by the width of the column.
  7. hman
    939
    113
    City:
    Tempe
    State:
    Arizona
    -Return to Top-
    Aw, shucks! So much for my brilliant idea. Sorry, guys.
  8. RodSME
    21
    3
    City:
    Cape Coral
    State:
    Florida
    -Return to Top-
    I didn't want to go into much more detail, but I probably modeled about 8 different ideas to stiffen the column in torsion. None of them was as good as the way I finally incorporated into the 619. I modeled adding a back plate to the top of the column above where the wrap around bar for the Z axis nut goes. It didn't offer any improvement.
    As I noted in the analysis, the measured deflection is about 2x the calculated amount. I guessed that a possible explanation for that is the fact that the model is one piece and the reality is made up of separate pieces. It's a bit of project to get at the back of the column given how I have the bench setup. The next time I open the back, I'll consider epoxying the vertical bars to the column. This should tie them in better. The only problem will be if the bars extend down too far. If they block removal of the lower pillow block supporting the Z axis lead screw, I can't permanently attach the bars. If I have to and it doesn't weaken the assembly, I may be able to take a bit off the bottom of the bars. I'll also use bigger pins to tie the rear plate to the internal bars.
    If I had realized that the mill had this design deficiency, I probably wouldn't have bought it. I bought it through craigslist, so I got what I thought was a good deal. I added a DRO and built a bench that's pretty elaborate, so I'm into it for too much to consider switching. I've learned to "nurse" my cuts along. Since I'm retired, I just have to remind myself I have the time to do the job more slowly.
    brino and rdean like this.
  9. majorm
    majorm United States Iron Registered Member
    0
    1
    City:
    Florence
    State:
    South Carolina
    -Return to Top-
    Ive been reading allot about epoxy granite over on the CNC zone site and am thinking about giving it a try sometime. My mental picture is to add some studs in the sides on the column and then use a piece of PVC to create the mold for the Z lead screw and block to move up and down. The rest would be filled with epoxy granite. Ill probably do the base at the same time and create a 3 or 4" riser for the column as well. I have the parts minus the electronics for a cnc conversion so all of this will be done at the same time. The epoxy granite looks pretty promising for what it is and should add a decent amount of mass and vibration dampening.
  10. RodSME
    21
    3
    City:
    Cape Coral
    State:
    Florida
    -Return to Top-
    In response to majorn regarding using epoxy granite to stiffen the column of the G0619, I'm sure it would do a great job of adding material, thus stiffness to the column casting. Just a couple of thoughts. It isn't possible without a major redesign (namely moving the z axis leadscrew to the front of the column) to close in the back of the column completely. See the photo that DAT510 included in his posting. Two, the two 3/4 x 2 inch by 24 inch bars add quite a bit of stiffness to the column. I don't know what the Young's modulus of the epoxy granite is, but steel is 30x10^6 psi, which is pretty stiff. The majority of the stiffness in my design is developed by closing in as much of the back of the column as possible. hman's post talking about closing in the column is right on the money. The more the column can be made into a closed cylinder, the stiffer it will be. Think of the base of a Bridgeport. Big and sort of conical shape. Most stiffness for the mass.
    Be careful not to lock in the z axis leadscrew and support blocks. Someday you may have to replace them.
    Rustrp likes this.
  11. Rustrp
    437
    63
    City:
    Sacramento
    State:
    California
    -Return to Top-
    The amount of rigidity you will achieve is limited by the slot that must remain open for the screw. Making a full connection with reinforcement from the top of the column, then along the sides and connecting to the base is close to as good as it gets.
  12. majorm
    0
    1
    City:
    Florence
    State:
    South Carolina
    -Return to Top-
    RODSME: Your comment made me go look up the Youngs Modulus of epoxy granite and lets just say homemade epoxy granite and your right on. While it does have vibration dampening and weight going for it its not as good as steel for stiffness. Ill have to keep thinking about this. There is a person with a cnc conversion that mounted the screw to the outside of the column but this was on a cnc conversion. There should be a video on youtube about his machine to show how it was done. It was another guy playing with epoxy granite and he filled the entire column with it so that was the reason.
    Thanks for posting your mod as well. Its great to see what people come up with to improve these machines.
  13. Sloth2009
    Sloth2009 United States Active Member Active Member
    90
    18
    City:
    Billings
    State:
    Montana
    -Return to Top-
    Random idea. Has anyone ever tried bolting a heavy frame onto the back of the column and the mounting it directly to the wall? Something that looked like a vertical bridge with 2 beams and support triangles between them. This would keep the top of the column from being unsupported It would be ugly but perhaps solve the rigidity issue. Even a cable anchor would help keep the column from flexing forward. IMG_5302.JPG
Share This Page
