Is there a breakdown somewhere of the effects of grit on various metals? For instance, 600 grit aluminum oxide sandpaper against hardened steel at X feet/minute with Y pressure in lbs/inch of grinding will yield a net loss of .001 inches/minute. Or equivalent type chart.
Probably sounds like a silly question. But I would like to know generally what I'm getting myself into before I begin a sanding/grinding process.
Thanks for any info!
