Sorry let me clarify, I have lots of sharpening equipment, bench grinders, belt grinders, diamond dressers etc, that I use for my plane blades and chisels,but most woodworkers take off the stock grey wheels that come with most grinders and replace them with cooler cutting wheels (typically white) at about 80x and with a grade of about"H" which is considered soft. All the sites(I've seen) explaining HSS tool bit sharpening use grey wheels,which I assume are aluminum oxide, but what grit would be considered coarse for this usage? 36x, 60x? and are they generally a harder grade than we woodworkers would normally use? say in the in the P - S range with a structure tending towards dense as opposed to open which would be less durable. Thanks again.
