- Feb 8, 2014
- 11,144
Normally they just press on/off without too much effort.
I used a 3-jaw puller to get mine off. Use some care when pulling, it is possible to break the pulley with too much pressure on the outside rim. Maybe a little heat concentrated on the pulley away from the motor shaft would be helpful. You may have to remove the endbell with the pulley half in place, then press the the pulley off using some thin plates in a press.
