A
Andre
Forum Guest
Register Today
I have a 4" Chinese RT, and it's a piece of junk. I took it apart today to surface grind all registers and important surfaces. The table was about .002" out of flat on the bottom, top of the table isn't flat or parallel The base was better, but still about .001 out. I expected there to be some tolerance, but after grinding everything to one or two tenths, which is easy on a decent grinder (unit is fairly small) I noticed quite a bit of slop radially between the table and base. No wonder all my indexes were uneven!
Are there any good, small RT's for under $200 or so?
