I am not sure if this is the correct forum... however my question is electrical...
At the airport where the gyro's are... we have an old golf cart we use to ride around the airfield... it is quite popular, given our hanger is one of the farther from the office and runway.
A week or so ago, the charger quit working... so I brought it home over the weekend.
After taking it apart, I find a BIG transformer, a fuse of sorts, an ammeter, a relay, and a half wave rectifier.
It appears the rectifier opens when a load is put on it... so I am thinking to find a new way to turn AC to DC.
The golf cart has 6 x 8V batteries, for a total of 48 volts. I might mention that one of them measures 4+ volts, two measure 6.25 and 6.33 volts, the other 3 measure 8+ volts... for a total of 41-42 volts. All the 6 batteries have been filled with fresh distilled water.
There is a relay in the charger that is supposed to verify connection to batteries, before starting the charger (controls the 120V AC circuit to the transformer)... I am wondering if the relay is failing... I do not have a variable DC power supply to test it.
Do any of you have experience with these chargers... any and all thoughts, suggestions, comments, pokes, etc... are greatly appreciated.
And one more question: Where would I find a half wave rectifier (two inputs, one output), that can handle 20+ amps @ 48V... preferably 30A would probably be better. THX in advance for any sources!
