I recently did some trading for a larger rotary table and got a 6" George Gorton Rotary Table in with the larger one. I have never saw one like it before. It tilts, and it rotates only by hand and not by a crank like most. There is vernier marks stamped on the side for setting the rotational degrees, but under the main plate, there is a smaller aluminum round plate with just one mark on it and a loose lever that is sharpened that will drop into the scribed mark. I did a search and have not found anything on it at all. So my question is....can someone tell me something about it, and is it mossing something or is this not technically a rotary table per se, but just a table that you can change angles on for milling and drilling, if that makes sense?
I forgot to mention that when the lever is dropped into the scribed mark, the table is set at 296 degrees on the vernier scale.
