The slowest travel I can get on this bed is .0015"/turn I need to get .0007"/turn. I'm getting a gun drill to use on some rifle barrels and would like to feed them with the apron rather than by hand.
The way I see it I have 2 choices:
1. Increase the head speed by double by using either a planetary gear system on the chuck,
2. reduce the lead screw speed by creating a gear setup where the reverse gears go to cut the speed by half.
I'm sure others have other ideas or have found a way around this.
Thanks
-John Barton
Thanks
-John Barton
