- Sep 15, 2017
- 321
Hi all hope you have had a good day
Im working on a new project and need a bit of help as i have never cut spure gears before and i want to get in the ball park for ordering involute cutters
Is this remotely correct ?
I have been racking my brain all day on working out involuted gear cutters with what I can find online
This is what I have come up with on my calculations please correct me if I an not correct
If I was to make a 40 tooth gear using following cutter
M 0.8 32 DP #2 cutter my outside diameter would be 1.312
If I was to make another gear using
M 0.8 32 DP # 3 cutter my outside diameter would be 2.562
From here how do I work out the diameter pitch so I can see centre lines we tweet the two shafts
I am looking for 45 to 50 mm between centers
Also how do you determine the depth if the cutter is not marked ?
If I'm totally wrong in my understanding of cutters please correct me
Any help appreciated
