    Dismiss Notice
G4003G Headstock Alignment
Discussion in 'GRIZZLY INDUSTRIAL INC.' started by Splat, Jun 16, 2017.
  1. Splat
    Splat Active User H-M Supporter-Premium
    114
    63
    City:
    here and there...
    State:
    New Jersey
    -Return to Top-
    A friend has had a G4003G for months now and finally getting around to leveling it, alignment, etc. and has asked me to help. He's not PC savvy so I'm his lifeline, so to speak. He surprisingly anchored his lathe to the floor after I advised him I had done so with mine. The lathe is leveled as close as he can get it using my machinist's level. He did the 2-collars test (I gave him Richard King's writeup on 2-collars test along with a few of my tips) using a 12" rod of 2"diameter 6061 aluminum. He's using the 3-jaw chuck with about 10" stickout with 1/4"-wide collars at the ends. Yesterday I remind him to lock the cross slide and now he's getting .002" difference between collars.... .002" over roughly 10".
    Running the level up and down the ways sitting upon the compound the bubble doesn't move so I know the ways are leveled. Only thing I can think of now is his headstock/spindle needs to be moved to get better alignment. The one strap we used to lift the lathe was really tight up against the front-side (closest to operator) of the spindle nose when lifting so I'm wondering if that moved the headstock over a bit. Now I didn't need to do this on my G4003G, thank God. Anyone know if there's a locating pin under the headstock or what's the best way to achieve the alignment? Thank you.
  2. fitterman1
    fitterman1 Australia H-M Supporter - Premium Content H-M Supporter-Premium
    64
    28
    Australia
    City:
    Adelaide
    State:
    Outside US / Canada
    -Return to Top-
    The only way to find out is to power off and disconnect (play it safe) and remove the front fascia panel and have a look. You'll find at least two studs or bolts inside there.
    The other two are most probably accessed from outside the headstock out back.
    I don't know about the G4003G but on the G0602 there are 4 studs clamping the headstock to the ways with no locating pins (tapered or not). There are 2 x grub screws on the two rear studs that give you a method of fine adjustment. If you find these are present and decide to fiddle them, then keep a small amount of tension on the studs/bolts so there is some friction to fight against while adjusting. Then nip up and test cut your collars for diameter. Repeat this procedure and continue to adjust until your happy with the results. Adjust any belting last. I scraped my headstock base flat (it was terribly warped) and adjusted it so the spindle was actually parallel to the ways using an mt4 mandrel and measuring in two planes. This got me under a thou over 10" and down to 3 tenths after test cutting collars. I was happy with that.
    For a gunsmith lathe your friend should be able to achieve better than that with your help. I'd love to help but I'm in Australia, anyway someone else will chime in as well with their thoughts if their familiar with this model. cheers Alby
    mikey likes this.
  3. mksj
    mksj Active User H-M Supporter-Premium
    1,440
    113
    City:
    Tucson
    State:
    Arizona
    -Return to Top-
    Most lathes usually need some tweaking of the headstock alignment to get the last few thousandth out. Unlikely it was changed with moving. That being said, there are other factors that can affect the two ring test such as any axial skew of the chuck. This is the information I sent to a friend recently on this. "If the lathe is leveled and it is not cutting true after leveling, then it is usually a headstock alignment issue, which is very common. The other factor is that the chuck has a slight angular skew so the piece will cut smaller at the tailstock end. You can chuck up something like a 1" round ground bar in a 4J, zero the TIR at the chuck and then check the TIR along its length looking at the +/- swing around 0. If the +/- swing in either direction of 0 is the same then you have some skewing of the piece in the chuck, but the headstock alignment is OK. If the reading is high in one direction then it is most likely a headstock an alignment. Looking beyond 12" is probably impractical, as both the ability to hold a piece true at that distance is unrealistic, you can get some slight deflection when turning, and in almost all cases you would use a tailstock. The two ring test works, but there is always some deflection by the cutter, and this will be affected by the DOC. "
    Headstock alignment on these lathes is pretty straight forward, there are 4 large Allen bolts that hold down the head, two are visible under the chuck side, the other two are under the belt cover side. I only slightly loosen the bolts. On the G4003G there are two headstock jacking screws just above the motor in the back. It takes almost no movement (maybe 1 degree or a slight tightening or loosing) to make major changes in the head alignment. I use something like a 1" bar chucked up and measure the TIR along its length, looking at the +/- swing range is centered around 0 as I move down the bar, you can then gauge the movement of the headstock adjustments. Lock down the head, recheck everything and then do the two ring test. On the tailstock alignment, I use a 4J and adjustment for minimal TIR at the chuck and the tailstock end, then take a cutting pass along the bar and measure at different points. I adjust the tailstock until the cut diameter is the same as the chuck end. Sometimes for precision work I will turn my material just shy of the final diameter, check the diameters and ever so slightly tweak the tailstock so it cuts true along the length. Too long a pieces or small diameter material can deflect along the length of the material.
    Just one approach.
    fitterman1 and mikey like this.
  4. ddickey
    ddickey United States H-M Supporter - Premium Content H-M Supporter-Premium
    443
    63
    City:
    Red Wing
    State:
    Minnesota
    -Return to Top-
    Is there a way to correct axial skew of the chuck?
  5. mksj
    1,440
    113
    City:
    Tucson
    State:
    Arizona
    -Return to Top-
    All chucks can have some skew when holding stock, this can vary by the size of the piece held, the torque and also how the material is held. Chuck jaws are often ground with a very slight taper front to back to apply even pressure across the clamping surface once tightened, some chucks only have a single pinion to provide consistent clamping like a PBA that I use. Also materials are not always concentric and may have irregularities which affect how the piece is clamped. In some cases, the jaws can be reground to account either TIR or skew issues, but it is not a simple task. Collet chucks tend to be a bit worse in my experience, of all my chucks my Bison 8" 4J chuck has the least amount of skew which is ~0.0005 at 12". Other chucks can be +/- 0.001 at that distance or worse. The other issue can be the back plate is not running true, so I check that and the chuck body for run out for both axis.
    wrmiller likes this.
  6. fitterman1
    64
    28
    Australia
    City:
    Adelaide
    State:
    Outside US / Canada
    -Return to Top-
    Don't forget swarf can cause a few headaches as well.
    Be aware of this when changing chucks.
    wrmiller and Tozguy like this.
  7. Splat
    114
    63
    City:
    here and there...
    State:
    New Jersey
    -Return to Top-
    Mark, thanks for the help. I haven't been able to look at the backside of either mine or my buddy's lathe (I assume they'd be the same though). I'll let you know what I find.
    As for possible causes of runout, good thoughts guys. I understand about possible skewing of the work via chuck, swarf, etc... Wouldn't I see any possible skewing when slowly turning the spindle by hand with a .0001" DTI on the work?
  8. fitterman1
    64
    28
    Australia
    City:
    Adelaide
    State:
    Outside US / Canada
    -Return to Top-
    Definitely if your not properly clocked in.
    Definitely if your spindle is bent. (Clock your register and even the spindle bore taper seperately).
    Possibly if your bearings weren't adjusted to a slight preload value. You'd know this is if chatter or uneven surface finish is present.
  9. Splat
    114
    63
    City:
    here and there...
    State:
    New Jersey
    -Return to Top-
    I've clocked the spindle and he's got no real discernible run out. We're not getting a really nice surface finish but I think that's from the motor vibrations which is why I got the thick rubber mounts from McMaster for mine. That, along with the link belt, really nipped that issue in the buttinski. I advised him to do the same to his but he hasn't yet. Everything's on hold until I can get over there and assist him, so pro'lly Saturday. We'll see what happens.
  10. ddickey
    443
    63
    City:
    Red Wing
    State:
    Minnesota
    -Return to Top-
    I just did this on my lathe. I had worked on my HS before so didn't think it would be out much. Used a linear motion rod so I know it is straight. Had about ten inches sticking out of the chuck. As I rotate the chuck I get +.004" & -.006" I continue rotating and get +.005" & -.005". You know that bugs me so much I don't know why my indicator does that. Anyway I decide to not mess with it. Obviously I have some skew going on. I ran an indicator along my 4J face plate and got ~.0004"-.0006". Sure would be nice to get rid of that skew.
  11. fitterman1
    64
    28
    Australia
    City:
    Adelaide
    State:
    Outside US / Canada
    -Return to Top-
    Check it again with another indicator. Yours may need servicing.
  12. ddickey
    443
    63
    City:
    Red Wing
    State:
    Minnesota
    -Return to Top-
    Disappointing as it is a brand new Teclock.
  13. mksj
    1,440
    113
    City:
    Tucson
    State:
    Arizona
    -Return to Top-
    You can get some movement in the indicator reading by just turning the chuck by hand, I use my VFD jog which is 6Hz, this is slow enough and I run the indicator along the bar while turning. Also try to put the gearbox in neutral as opposed to in gear if turning by hand. The dial indicator head I use has a flat convex head, so more contact area, if your dial indicator is off from vertical then you can easily see a variance of 0.001". At 10-12" on a test bar I will usually see a swing of under +/-0.001", you are getting quite a bit more. The problem with most 4J independent chucks are the jaws have very course serrations so it may not clamp evenly, my 4J jaws are 0.200" at the tips with no serrations. You might try to repeat the test with a 3J, you are not concerned about the TIR, just the swing around "0" remains the same magnitude in either direction. This tells you if the head is aligned relative to the carriage position. Beyond that the two ring test can be used to further fine tune/check the alignment while cutting, this is also true of the tailstock once the head is aligned. Many of the newer dial indicator use the name of some well known prior manufacturer, but the internals are often lacking. My go to dial indicators are the Starrett 25-511 or 25-611, they will read 0.0001" and have a range of 0.200". NOS are lightly used ones come up at auction in the $60-100 range, super nice to work with and very accurate.
  14. ddickey
    443
    63
    City:
    Red Wing
    State:
    Minnesota
    -Return to Top-
    I used my Teclock, an old Starret, a cheap Shars DTI and my Compac DTI. Every rotation on every one was different. I ran it in back gear also. I could really tell at that point because the dial was vibrating so badly. That turned me on to the fact of vibration. Is it normal to have a lot of vibration in a work piece?
    Then I tried the 3J. It seemed more accurate as far as holding the same readings per rev, still was a little different though.
    FYI my 3J showed +.025" & -.025" @ 10" length.
  15. Splat
    114
    63
    City:
    here and there...
    State:
    New Jersey
    -Return to Top-
    OK. We got a little more done...kinda. We checked his 3-jaw and it looked clean. We didn't clock it...should have. My buddy slightly tightened up (3/16-1/4 turn) the back mounting bolt at the tailstock (TS) end of the ways in thinking this would bring the cutting tool closer to the work at the TS end. He did the test and no change in collar diameters. Still a 0.002" difference over 10". I'm thinking he should shorten the 2" diameter 6061 rod he's using to about 8"...giving him roughly 6" stickout and switch to the 4-jaw. If not that, then add a 0.001" shim under the operator side TS-end mounting bolt. The problem is he put silicon under the lathe where it meets the chip pan. :rolleyes: I'm glad it ain't my lathe but I feel for the guy. I still remember how it was being a lathe newbie! :confused 2:
  16. Splat
    114
    63
    City:
    here and there...
    State:
    New Jersey
    -Return to Top-
    Finally had time to help my buddy out some more. We put 0.002" shim under the tail stock on the operator side. Tightened up all the bolts again and let it sit for couple of days for the helluvit. Did another 2-collars test cut. For the record, the stock was 6061 2" diameter with 10.375" stick out from the chuck jaws. I measured the collars using my new Mitutoyo 101-118 0.0001" micrometer. Figured it was a good reason to get a ten-thou mic now. :grin big: We got 0.0003" difference between collars roughly 9.75" apart, the larger diameter at the TS end. Ya think more tweaking or leave it? I'm for leaving it. IMO that's pretty darn good for 2" stock with that much stickout.
    hman likes this.
  17. ddickey
    443
    63
    City:
    Red Wing
    State:
    Minnesota
    -Return to Top-
    Did you stop the lathe, return to the TS end and make a spring pass? Bet that would have taken out the three tenths.
  18. Splat
    114
    63
    City:
    here and there...
    State:
    New Jersey
    -Return to Top-
    Yep. Spring passes done until no marks are made on the collars when running the tool back to the TS end.
Share This Page
