G0762 Benchtop Mill — Z-crank 0.118" Per Revolution?
Rex Walters
H-M Lifetime Diamond Member
Apr 21, 2015
654
I'm a recent owner of a Grizzly G0762 benchtop mill. Overall I'm quite happy with it, but a question came up in another thread regarding the Z-axis head crank: was it 0.100" per revolution or 0.125"?
I never use the head crank for anything other than gross positioning. I use the dial on the quill (with the feed knob engaged) for precise positioning in Z.
So I pulled out an indicator to answer the question, but now I'm more puzzled than ever. I've measured umpteen times, and the answer keeps coming out to 0.118" per revolution (or 3 mm).
Is it really possible that despite inch dials in X and Y as well as Z (on the quill) that the gearing is metric for the head crank? Not only is it annoying, it makes creating a dial for the crank difficult. I'm starting to regret only buying a two axis DRO....
Nothing special about the setup, just a 0 to 1" dial indicator:IMG_0440.JPG
Any comments or suggestions for creating an inch dial for the crank will be appreciated.
Rex
That is not abnormal in machinery coming from Taiwan and China.
Maybe you can Ebay your 2 axis DRO and get a 3 axis one. The convenience and precision is worth the extra $$$.
I have a 2 axis DRO. I fitted a digital scale on the quill to serve as the Z axis. Not quite as good as a real DRO, but it is a million times better than the scale on the hand wheel. Only cost about $35 from eBay.
In the absence of a DRO for the mill head, just use a dial indicator on a magnetic base. Attach the magnetic base to the head, with the dial indicator probe on the part, and use the dial indicator to read-out how much the head moves.
Even when you can trust the dials on a mill, this is more convenient (since you don't have to count rotations) and accurate (since it accounts for backlash). I do this on my lathe all the time when I need to move the cross slide or carriage by a precise amount.
Personally, I would shop for a 3 axis DRO. Life with it is so much better.
did You use this for full z axis travel ? Can you post a pic and link you spoke of thanks
I have a PM25MV that has a fine digital z axes feed (quill only) but not for full column Z travel. I am thinking about using a 12 dig caliper to and modiphy for this use looking for ideas.
I have a picture on my iPhone if I could figure out how to post it. Mine is a 6"'and covers the 5" quill travel.
Nice. I have the same one in black on my quill.
Sorry I chimed in perhaps posted in wrong place. Forgive me brothers .... However like to give a quick shout throw one thing out there if someone catches post thanks .
I have A PM25 MV little dif set up than the Griz . My model came with quill travel down feed DRO (fine adjustment ) but not Full Z travel on column . I was thinking of adding in addition to fine feed DRO. . Like to see a pic of someone who may have put Z depth on the side of column . Or a mod like wise thanks
