I recently purchased a grizzly G0752 metal lathe. And initial problem with the motor was quickly resolved with grizzly sending out a replacement motor I switched out the motor and began using the laser only to find that I cannot use a half inch cutting tool with the leg because it will not go lower enough to be centered on the material I am cutting . The lowest the cutter will go is 1/16 above center
I I called Grizzly Tech Support, explained the situation and they implied that it was within specifications. Also I called on the 32 day of ownership so there wasn't much that could be done.
The bottom line is the compound is 1/16 to high and there is no adjustment.
I wonder if anyone else has this issue with the G0752 lathe?
Thanks in advance for your comments.
Jojo
Jojo
