Hi all; I have a small problem with my Grizzly lathe steady rest, I have a project that requires the turning of a 2 inch round stock. Because of the stick out from the chuck I got the steady rest (first time ) out to set it up in the lathe, and found out I can't use it, it would not accept the 2in bar.
my question is has anyone run into this same problem and if there is a work around , or do I try to make one.
Thanks
John
Thanks
John
