G0704 Arrives Friday
cg 2005
Mar 7, 2012
149
I started an activity with Grizzly last week requesting they verify the motor wattage based on my research that some motors had been shipped at 600 watts. I was told that all the new machines were in fact 750 watt motors and they were aware that some were previously shipped at 600 watts.
Ordered the G0704 Sunday night after confirming that it does in fact have a 750 watt motor. I got an email this morning stating the mill would be in Orlando Friday. Very nice turn around. It is great not to wait weeks or months for a machine.
I am hopeful it will be a good compliment to my other mill and two lathes.
I have no immediate plans to go beyond adding the power table feed and lowering the coarse Z feed wheel.
Congrats Cg! :drinkingbeer:Of course we will require photos! :biggrin:
:tiphat:Nelson
sweet. congrats!
post some photos and tell us how you like it after delivery.
what power feed are you planning on getting for it?
Congrats I have a g0704 with power feed. I got the power feed from lathemasters. as it was about $50.00 cheaper than grizzly for the same part. http://www.lathemaster.com/POWER FEED LMT25L.htm The color isn't exsact but it works great. If in fact you get a 750 wat motor I will have to get mine replaced. Now I wan't to build a power feed for my X axes. Just looking for a good dc gear motor for it.
Yes, congratulations! I don't have anything bad to say about Grizzly lathes and mills.....except they sure don't run like an old Bridgeport. Or a Hardinge.
cg 2005
What method are you going to use to lower the Z feed handwheel?
Mike
I need to actually see the mill in the flesh, but I am inclined at this point to use a couple of my old countershaft sprockets and a chain from one of my dirt bikes. That way the cost will be zero.
I would like to get it down to a point that is 3" or so above the table. I don't need to use the drill aspect so I am thinking about removing the quill spokes entirely.
I hear ya, but being on a fixed income and not having the space or power required I can make it work.
I hear ya, but being on a fixed income and not have the space or power required I can make it work.
I did not mean anything bad by that, I'm in the same boat. Years ago, I looked and scanned around for 2 years before I pulled the trigger on the G4003G, and the 3102 mill. I couldn't justify the shipping costs on the old Bridgies and nicer lathes. Not only that, some of the old dinosaurs needed more work than I wanted to put into them. The Grizzlys surprised the hell out of me. The mill is not as big or bad as I wanted, but it works fine for what I do.
Hi,
I was unaware that the 704 was made with a smaller motor. I thought they were always 750W.
dalee
The lable and manuel all say 750W but the tag on the motor says 650W at one point thay just left the watts off of the motor tag but still the same size as the 650 motor. I havent heard of any body accutly getting the larger 750W motor.
That is really sad to hear that they would be so deceitful and then to potentially knowingly lie about it. I'll pull the cover first thing and take a look. I doubt it reallly makes much difference for my milling needs at this time.
