    Dismiss Notice
First Steam engine Question
Discussion in 'QUESTIONS & ANSWERS (Get Help Fast Here!)' started by faavs730222, Apr 20, 2017.
  1. faavs730222
    faavs730222 South Africa Active Member Active Member
    1
    8
    City:
    Danielskuil
    -Return to Top-
    I am trying my hand at my first Wobbler Steam Engine. I made the Cylinder from 25mm Alu and drilled a 13mm hole for the piston about 6mm off center. Now I would like to mill a flat on the side of the Cylinder for the Inlet and Exhaust ports as well as the pivot point. I have to line the Cylinder up in the Milling Vice that the Flat and the 13mm hole are perpendicular. I tried eyeballing it in the vice but I would like to do it more accurately, but for the death of me I cannot find a way to do it. What would be the easiest?
  2. mikey
    mikey Active User H-M Supporter-Premium
    1,741
    113
    City:
    Honolulu
    State:
    Hawaii
    -Return to Top-
    I'll take a shot at this and the guys can come along and tell you the right way to do it.
    I think I would turn a plug from Delrin to be a line to line fit (OD of plug and ID of bore are equal) for the bore. I would attach/screw the Delrin plug to a flat piece of stock so the bottom of said stock is below the bottom of the round work piece when assembled. Then I would put the plug into the bore, drop the whole thing in the vise and let the bottom of the flat sit on the bottom of the vise. With an indicator, I would tap the work one way or the other to get the highest elevation at the top. That should get you on center. Clamp it all down tight and mill the flat.
    There is probably an easier way but its late and I can't think of one.
    faavs730222 likes this.
  3. cascao
    cascao Active User Active Member
    330
    63
    Belo Horizonte, MG Brasil
    City:
    Belo Horizonte
    State:
    Outside US / Canada
    -Return to Top-
    How I did this:
    1 Miled the flat (on a lathe)
    2 fixed the cylinder in 3 jaw chuck. One jaw against flat.
    3 Bored the hole.
    T Bredehoft, faavs730222 and mikey like this.
  4. terrywerm
    terrywerm New Member Liaison Staff Member H-M Supporter-Premium
    664
    113
    Neither here nor there
    City:
    Jordan
    State:
    Minnesota
    -Return to Top-
    Ideally, the flat should have been milled first, but since you drilled the cylinder bore first, other methods will need to be utilized. Mikey's idea should do the trick and should be as good a method as any.
    mikey likes this.
  5. tq60
    tq60 United States Active Member Active Member
    149
    43
    City:
    madera
    State:
    California
    -Return to Top-
    That is a tough one maybe.
    So yiu have a round part with a bore off center and it needs a cross drilled hole as well as a flat side.
    Make a rod a snug fit to the bore and several inches longer so it protrudes a bit.
    With a X block or vise you can lay the part in the vise with the rod then rotate until rod is highest or lowest point and measure with dial indicator in drill chuck.
    If flat goes on thickest side then rotate until rod is at lowest point.
    Now mill off the flat side.
    Now rotate until flat side is against jaw and then drill cross hole.
Share This Page
